Hello,
I hope this thread becomes sticky so that all of you can benefit from using it. I have a mad passion for cars and especially the GT-R's.
The reason for creating this thread is to:
1. Have a quick and easy way to get required part numbers
2. Have a "directory" style way of listing the numbers
3. Become more knowledge on car setup, through experience
So below will be threads dedicated to each model listed above in the Topic Description and they will be continuously updated from time to time. Essentially this is a labour of love and I will try and get as much up in my free time.
Good Luck and Happy searching. :)
Data integrity is given here to use at your own risk. Whilst care is taken to attain the correct number, the responsibility is on you to confirm with who you have you part supplied by.
FOR REQUESTS: Please specify the following, the more the better and easier for me to get the right number for you.
Model: R32 R33 R34 S15 etc
Year: MOST IMPORTANT!
Colour: Colour if body part.
Model Number: Blue plate - Really handy if you get this
Chassis Number: Blue plate - Really handy if you get this
Input Recognition List :iluvff::D:)
Thank you for your help to this list of goodies that will certainly help all skyline owners.
arep3, intune,
Edited by arbess
https://www.sau.com.au/forums/topic/172870-nissan-genuine-part-numbers/
Sounds like this could be a great reference thread.
Lets keep it to confirmed Part NUmbers and requests for part numbers only....maybe our FAST users can help with supplying details and I already have a fair few numbers if there are any requests
* Off topic posts will be removed *
This will look a little plain but as soon as i can get some general parts together I will list them.
check back soon
R32
***GT-R***
Engine
- Belt | Fan & Alternator AY140-40880-
- Belt | Compressor AY140-40925-
- Belt | Power Steering AY140-40950-
- Belt | Timing 13028-20P25-
- Clutch | Disc 89 to 93 Feb 30100-05U00-
- Clutch | Disc 93 Feb Onwards 30100-12U00-
- Clutch | Cover 89 to 93 Feb 30210-05U01-
- Clutch | Cover 93 Feb Onwards 30210-12U00-
- Clutch | Release Bearing 89 to 93 Feb 30502-21000-
- Clutch | Release Bearing 93 Onwards 30502-12U00-
- Clutch | Booster 30630-05U01- Around $180.00 - Nissan 2007
- Element | Air AY120-NS001-
- Filter | Oil AY100-NS007-
- Pump | Water Pump Assembly 21010-58S25-
- Pump | Oil Pump
1989 Aug to 1993 Nov 15010-05U10-
1993 Nov Onwards 15010-05U11-
- Sensor | Oil Pressure 25070-30P00-
- Strainer | Fuel 16400-72L00-
- Thermostat | Water 21200-42L05-
Chassis
- Brake | Kit for 89 to 93 Feb AY040-NS003-
- Brake | Request Kit for V-Spec /II
- Shaft | Front Drive RH 39100-23U00-
- Shaft | Front Drive LH 39101-23U00-
- Shaft | Rear Propeller 37300-05U00-
- Steering | Power Steering Rack 49001-05U00-
- Steering | Rack Request for V-Spec /II
Exterior
* Request for colours other than KH2 Gun Grey
- Air Spoiler | Front (Lip) 96015-05U00-
- Air Spoiler | Rear Kit (Unknown Colour) 96030-05U00-
- Boot | Lid (Unknown Colour) 84300-04U30-
- Front Grille KH2 (Gun Grey) 62310-05U03-
- Spoiler | NISMO (Boot Lip) K6032-06U00-
Interior
- Heater & Blower Unit | Actuator Assembly - Mode 27731-53E00-
- Finisher | Right (Rear Quarter window Surround) 2 Door 76934-04U00
- Finisher | Left (Rear Quarter window Surround) 2 Door 76935-04U00
Electrical
- Ignition Unit All years 22020-05U00-
- Coil | Singular 89 to 92 Aug 22448-02U10-
- Coil | Singular 92 Aug Onwards 22448-02U11-
- Engine Management (ECU)
08/89 to 11/90 = 23710-05U02-
11/90 to 08/91 = 23710-05U03-
08/91 to 04/92 = 23710-05U60-
04/92 to 02/93 = 23710-05U61-
02/93 onwards = 23710-05U62-
Cables
- Speedo Cable Manual Transmission 25050-05U00-
GTS-T
Cables
- Speedo Cable Manual Transmission 25050-02U00-
- Speedo Cable Automatic Transmission 25050-03U00-
Engine
- AAC Valve Gasket 23785-40F00-
COMPATIBLE ITEMS
Spark Plugs are universal throughout GTR/GTST Please ask for RB20DE or any other variations
Model Years: 89 Onwards Spec Code: PFR5A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 5
Model Years: 89 Onwards Spec Code: PFR6A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 6
Model Years: 89 Onwards Spec Code: PFR7A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 7
Electrical
- Heater & Blower Unit | Actuator Air Mix 27742-77S60-
- Heater & Blower Unit | Actuator Air Mix Kit 27732-01U00-
Edited by arbess
  • Like 1
R33
***GT-R***
Engine
Exterior
Interior
***GTS-25T***
Engine
- Belt Fan & Alternator AY140-40850-
- Belt Compressor AY140-40910-
- Belt Power Steering and Oil Pump AY140-30845-
- Belt Timing 13028-20P25-
- Filter Oil AY100-NS007-
Exterior
Interior
Body
Protector - Front Fender RH 63842-15U00- (Splash Guard) ***All Models***
Protector - Front Fender LH 63843-15U00- (Splash Guard) ***All Models***
Protector - Front Fender - Front Piece RH 63844-15U00- (Splash Guard - Front part) ***Up to 1996***
Protector - Front Fender - Front Piece LH 63845-15U10- (Splash Guard - Front part) ***Up to 1996***
Protector - Front Fender - Front Piece RH 63844-26U00- (Splash Guard - Front part) ***1996 JAN onwards***
Protector - Front Fender - Front Piece LH 63845-26U10- (Splash Guard - Front part) ***1996 JAN onwards***
Edited by arbess
R34 I think the fast only covers to a certain point in time for r34
***GT-R***
Engine
Exterior
- Badges Badge Set for GTR: GTR Front Grille, GTR Boot, Nissan Boot H4896-AA400-
Interior
***GTT***
Engine
Exterior
Interior
Edited by arbess
***Moderator could you please keep the above comment for future reference***
correct me if I am wrong but isn't there already on of these? :)
I shall correct you if you like :D
The other one just covers R33 Parts, leaving out... where shall I start....
r30, r31, r32, r34, v35, WC34 (Stagea??), z32, s12, s13, s14, s15... etc the list is obviously Gi-normous.
Mainly I would like to focus on the RB series, CA and SR, also VQ and VG.
Enjoy.
16 JUN 07
R32 GTR has some now.
19 JUN 07
R33 Updates - Body Splash Guards
20 JUN 07
R32 GTST - speedo cables
Please start your requests as it is very pain-staking to look at all the parts. Have fun
Edited by arbess
Hey all, here some info for you all
Edited by arbess
Hey all,
I just spoke with Nissan and I am able to order parts from them at cheaper than retail prices.
Shortly I will be making a website that will assist those who wish to source GENUINE nissan parts.
The reason I want to do this for SAU is because, I found it very difficult to get a part from a wrecker and explaining what I need. Not just that I am a big fan of customer service and most places just dont give you the right respect you deserve.
Besides that listed above, some wreckers want BIG DOLLARS for 2nd hand parts, which give you no assurance for condition. I actually found out that one place in brisbane was charging $10 less than brand new and it was 15+ years old?!?!?! I'm sure most of you know that cant be efficient.
I will be looking for orders soon from as many SAU owners as I can get so I can get a bulk order sent for the first batch and then continuous flow from there, so i need as much support as possible. - ADMIN I will be in contact with you about this as soon as i am set.
Ok dudes, shall let you all know how I go.
-Arbess
ENGINE R32 GTR
GTR N1 Water Pump 2101024U27
Crankshaft Oil Seal 1351010Y10
Turbo Water Hose (small elbow) 1405505U22
Turbo Water Hose (long) 1405505U21
Timing Belt 130285L327
INTERIOR R32 GTR COUPE
Finisher Right (Rear Quarter window Surround) 7693404U00
Finisher Left (Rear Quarter window Surround) 7693504U00
Edited by intune
can you confirm the part number for the "mode door actuator" this actuator controls the vents position for the climate control. head, head/feet, feet, demister etc. located on drivers side of heater box. i found 27733M. there just seams to be more needed in my opinion.
Model: R32GTR 1989
BNR32003667
Cheers, Ron
Model: R32GTR 1989
BNR32003667
Cheers, Ron
Sorry dudes been quite busy with work lately.
Anyways, I found the number you are looking for which is referred as Actuator Assembly - MODE 27733M. I did not find the actual part it self, maybe i missed it, but i found the part number to take to nissan.
Actuator Assy - Mode 27731-53E00-
I have a feeling from my experience that this will be similar to other nissan cars as the number reflects something other than skyline numbers. but should be easy to find.
good luck happy hunting. and your car is 1 month younger than mine =)
ENGINE R32 GTR
Thanks for your input,
I checked all those numbers and they all come up ok.
I can confirm the Finishers as they were easy to locate, but the others were a little hard. The timing belt number im not sure of, so i wont be changing the one above.
well done!
Edited by arbess
1 month younger! YAY! i thought mine was old as! :laughing-smiley-014:
i spoke with a Nissan dealer and they say that is isnt a part for a GTR and that its worth around $1200+GST.... :dry:
Tried a different Nissan dealer and they say it has to come from Nissan Japan. It will take around 2 weeks and is a total of wait for it.... $189.40!
Thanks for your help arbess
Guys, when looking for genuine parts from Nissan, it can pay to shop around. Also having part numbers on hand along with your Japanese chassis number and model number makes life a ton easier.
Cheers, Ron
need to know the part number for 1992 r32 gtst aac valve gasket. would be great help
cheers
if the AAC your talking about attaches to the back of the plennum rb20det, then here it is
Added
Edited by arbess
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
