Hello guys,
im actually searching for a R33 GTS-t RB25DET complete engine gasket set-number, i would be very thankful
if you could supply me with one.
Greets, Artur.
I have several years for this. tell me your VIN code and i will give you the exact number you need.
Hi there
I want to know the part number of the two arms that hold up the boot lip for a R34 GTT 4DR...and also will i be able to order a repair manual from nissan for my car...Thanks
Anyone please help...need those arms ASAP~~~THANKS~~~
Hello mate,
the engine cam off a 1995 Syline GTS-t Series I, i do not have a VIN because the engine is in my S13 now.
I would be very thankful if you could supply me with an engine gasket kit number for a 1995 Rb25DET Skyline.
I do also need the part number of the complete clutch master cylinder of the R33 Skyline GTS-t Rb25DET.
Thanks in advance.
Greets, Artur.
Edited by Behind Horizon
Are you asking for the boot hinges? They look like folded horseshoe shaped steel that acts like the hinge for the boot lid.
The program used to find these part numbers has a lot of car models stored in it. It's quite difficult to pull a part number out of it without supplying it with a lot of info. VIN numbers give me the exact model car you have. This makes life a lot easier when searching for part numbers. I don't want to give out wrong part numbers, have you order them, pay top dollar, get the part from Japan and then realise they are not the right part.
To make it easier for me, the more info supplied from you the better.
VIN number is like GOLD
Model and year come a close SILVER
And you will get nothing out of me for BRONZE (Which is a brief description of something that could be out of any make or model.)
Cheers, Ron
Hello mate,
Thanks in advance.
Greets, Artur.
Right-o! The year and RB25DET made it a lot easier. I hope this is right. Gasket Set: 10101-17U27-
The Clutch Master Cylinder for the same year car is 30610-21U91-
Hope these help. Ron
Cheers, Ron
Ok...My VIN is 6U90000ER34007892..Model is 1998 ER34 GTT 4 DOOR SEDAN...No sure what they call(pretty sure is the one u are talking about) but those steel that stick up is what im after...Thanks Ron....post-27454-1188905225_thumb.jpg
Perfect! This is exactly what I need. Just for future reference, your Japanese VIN is ER34007892. The 6U90000 thats at the front is what gets added to it when it gets compliance.
I'll look this up for you as soon as i get a chance. either close to midnight tonight or tomorrow arvo.
Cheers. Ron
Cheers. Ron
RH boot hinge is 84400-AA000-
LH boot hinge is 84401-AA000-
Enjoy. Ron
Hi,
Car details:
R34 GTR V Spec II NUR
Build date: June 2002
VIN: BNR34403675
Part numbers I am after please:
Rear quarter windows on Driver's and passenger's side and seals. Are the seals joined to the rear quarter glass? and therefore have to be purchased together?
Can you supply schematic of how quarter windows are attched?
Thank you
Hi,
Car details:
VIN: BNR34403675
Thank you
When I ran your VIN number it didnt show up in the records. I added all of the info you gave me and this is what i found. I hope its what your after
RH 83306-AA100-
LH 83307-AA100-
Just asking if you guys would know if these are the right parts - someone with nissan fast setup maybe?
Anyway your feedback would be great.
Oh my car is R33 GTR 1995 model.
Nissan OEM BCNR33 GTR Crank Angle Sensor
"NISSAN SENSOR A-CRANK 23731-02U11" ?
Nissan OEM GTR N1 Oil Pump
"NISSAN ASSY OIL PUMP 15010-24U01" ?
Also one other question I was getting block bored & honed to 86.5mm and was wondering if Tomei RB26 Gasket Kit (1.2mm) (87mm) would suit. As far as I can tell tomei only make a 87mm and an 88mm gaskets.
Sorry don't have car atm but you could use this r33 GTR one:
1996 R33 GTR - BCNR33-024671
Cheers,
Pen
Edited by Penfold
whats your vin number ?
Cheers,
Pen
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
