Looking for some trim parts for my S15. Looking for the outer door trim that sits on the top of the metal door and has the end that has a bracket that is screwed to the door itself. I need both Left anf Right.
Next is the metal track that runs perpendicular and sits in front of the quarter glasses and is the housing for the rubber seals. I need both sides in those as well.
Lastly, I need all the rubber sealing that fits around the door on the body of the car, not the door, that seals the door to the body of the car. I already have the door rubbers that attach to the door but not the one that attaches to the body. Can anyone help me please as I need these urgently.
If I can get pictures I can confirm. I also need these small items shipped to me in Trinidad in the Caribbean, postal code is TT. If they can be had used as well I am interested as I need them urgently please.
Jason.
Jason.
for the first ones ( door belt moulds ) part No.
80820-85F10 RH
80821-85F10 LH
for the second request i am not to sure the first to No. are retainers that look to hold the top door weather strip. and the seconed No. look to hold the QTR glass it's self
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
and for your final request i would need to know more info on your car. I can't help u with shipping or prices, sorry
80820-85F10 RH
80821-85F10 LH
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
Thanks again.
Hi Guys
Forgive the idiotic nubi question, but I'm looking for the part number for a '00 R34 GTT (RB25DET Neo) Engine Loom..
If there are multiple part numbers is it possible to get a listing?
Thanks..
Hi Guys
Thanks..
what parts do u need for tis engine wiring loom because there are about 3 looms that do all of the engine bay. and more info would help like a vin number
hey,
do you guys have the part number for the studs and nuts
R32GTR
1. Turbo to dump pipe
2. Turbo to exhaust manifold
is there a part number for a turbo gasket kit
there is a gasket kit Part No. 14401-05U25
If it helps, from what I have been told I need them all, as the car is a NA+T transplant. VIN number won;t be much use as the car is originally a NA and this is to a stock Turbo ECU that is being attempted to get working right :down:
Hence would need part numbers for the stock turbo gear from any 34 GTT, the more the merrier.
  • 4 weeks later...
Hi there,
Can someone help me out with part numbers for:
R33 GTR bonnet hinges; left and right.
R33 GTR bonnet catch/upright.
R33 GTR guard raiser brackets; left and right.
Having a bit of trouble finding these locally so am looking at sourcing them from Japan.
Thanks,
Rob.
Hi can i get the part numbers for:
r34 xenon drivers side headlight
r34 gtr bonnet, fenders left hand and right handside,
thanks.
does anyone know where i can get these parts other than nissan genuine, they keep bothering me about these part/model numbers
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
