Hey guys i have been looking for this V power racing fuel for a while now and the car definately runs better.
Thought i would share the location with others if you dont already know.
Northside of Brisbane - Shell Sangate Rd Virgina.
If anyone else knows of other locations list them here :thumbsup: .
https://www.sau.com.au/forums/topic/173152-v-power-racing-fuel/
  • Replies 47
How much per litre Sub?
It does look to be the fuel of choice. Have you read the article on the MoTeC site: http://www.motec.com.au/fueltest/index.htm
I know a few track day guys who are switching to it.
Yeah interesting facts, some good info. I actually saw that episode on the testing and since then have been looking for it.
Finally found it thanks to my old man who found it by mistake.
Thats why i think its good to list other locations for people who have been looking for it.
The car runs alot better.
i got some of this at the shell on hawthorn rd, brisbane yesterday i was surprised to see they didnt have any normal premium in there, well not that i saw anyway. (didnt look to hard though) payed $1.44.9
Is that the first time you have used it, did you notice a difference.
hmmm i always favoured shell stuff (optimax prior to v power) cos that's what they use for the v8 supercars (shell makes them one big batch at the start of every season and they all draw from the same batch to keep things stable) or at least they used to.
so when i bought my skyline (all of about 3 months ago) i took it straight to shell and filled her up and she felt great. but then the second tank felt like shit. so i switched over to caltext vortex with mixed results.
maybe i'll give shell another go....
edit: are all v-power's 100 octane?? i think, but can't be sure that the one i used was 98??? Hungry Jacks over the highway from mudgeeraba on the goldy if anyone knows.
Edited by made_guy
Today i payed $1.45L i think thats a fairly stable price as normal fuel was only $1.16L
yeah it is a bloody good fuel but i refuse to pay for them now...the price used to change as the pump price changes, but now because the market is so special, no matter how cheap the normal petrol is, the price for v power racing will be set at 145c per litre...rip off if you ask me..i can stay on V power untill the special occasion comes
to add the location,
Shell Albany Creek ( on the way to Mt Glorious :sorcerer: )
Shell on Coro Drvie neae Wesley Hospital
and yeah the fuel is great for my car been running on it for 3-4 months straight, only just came off to v power and already notice the diference..
the ethanol is good in a way, as it cleans everything in the engine as it gets passed through. Its almost as good as having water injection except its in the fuel. However because its partially made up by ethanol the fuel isnt as dense and it also burns leaner, so when being tuned it needs to be richened up abit in comparison to normal fuel. By all means you should get a little less economy from a tank because of this. However it does have a higher octane rating, so it sort of works itself out. Think of it like methanol, it burns lean and cold, thats why you need to squirt 2.2 times as much over std fuel. But the octane rating of it is astronomical.
Thats how i see how the ethanol helps, whether its right or not is beyond me.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
