Hey there
im almost finished my rb20det into my 180sx conversion
just wondering is it still possible to use my car with stock ecu after i change the turbo to a t04e or do i need to buy a EMS?
Mod my car have are:
Trust FMIC
3" turbo Back exhaust
t04e (going to run 10-12psi) Turbine .63 Comp .60 (too Big? Aiming for 220-250rwkw?)
Os Giken Adjustable Cam Gears
walbro 341
Should i get a rising rate Fuel Pressure reg?
Will my car run like a sack of *poo*
or will it have basically small to no Change on how it will run?
Cheers Fellas
William
Edited by XtremeChief
https://www.sau.com.au/forums/topic/173635-rb20-turbo-to-t3t4-t04e/
you wil have lag, lag, lag.
you will need a retune 100%. just have your stock ecu remapped :D
i dont mind lag lol
but....
will my car be very much driveable still as i wont have enough moeny for remap or ecu before end of this month and i wanna get it mod plated and on road before july 1st lol
sigh...
Do yourself a favour and have a look in the rb20 sticky thread at the top of the forced induction forum and see what turbos work on an rb20 for what you want to do.
then do a search for t04e and see what people think of them.
Then decide if you still want to install it.
car will run fineish under 5,000rpm i.e before you hit boost
if you want to putt it round to the tuners it should be fine just keep it off boost and make sure you still have stock fuel pressure on the reg
and not way under or something stupid
ps t04e will suck the wang if your only gonna be running 10-12psi you must have low power hopes i.e under or around 200rwkw
why not just go a vg30 turbo or a rb25 they will be much nicer to drive and still make or get close to the power you want
Forgot to mention turbo has Turbine .63 and Comp .60
Should of done some research but impulse bought :action-smiley-069: but can anyone see any Pro's to this turbo on a rb20det and what would cons be?
sell that piece of crap turbo and buy something else, put a stock one back on and save your money for something thats actually good.
Buy a sliding hiflow, you can't get cheaper. It bolts on and unlike the turbo you have it has an actual power curve.
Edited by rev210
i have a similar turbo on my rb20 silvia...
specs are:
50 a/r compressor
.63 a/r turbine
.57 trim
still running on the standard computer and its running REALLY rich...
its not pinging and not detonating... but it sure as hell needs a tune..
i have no boost before 4000rpm... but then it pulls (sideways) until redline...
i would strongly recommend getting a tune sooner than later... no point running it without a tune...
The first RB20 i remember being worth is salt on SAU was CLint32 back in about 2002. He ran a HKS TO4E kit that was released for the RB20. He made good power, ran 12s, though i dont know exactly how responsive it was. But provided its an RB20 kit then you could do far worse. Hell grab the kit, run it for a whiel then update to a newer turbo, the manifold and wastegate alone are worth buying the kit for
IMO the only "T3/T04E" - actually TA34 in Garrett speak worth having is one called a TA34-1 , do a search . Is supposed to work reasonably well on an RB20 . T3 flanged , .58 turbine housing and I think a 37 or 40 trim T04E compressor .
Hmm couldn't find much on my quick look. I'd shoot for a 50-trim T3/T04E with .48a/r turbine housing. They're pretty reasonable spool wise for a T3/T4E and are capable of some good power. Not to mention cheap:
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=TBN
thats for a externally gated
though aint it?
http://www.skylinesaustralia.com/forums/in...st&id=19707
Thats a garrett factory fitted T3/T04E on a GTSR. They can work ok, for an old school turbo, if the combination is right. Thers a million types of T3/T4 so its hard to know what will happen untill you throw it on.
It is a .60 TO4 compressor housing and the exhaust I beleive is 0.63, same size as whats on a VLT I beleive. No information on trims.
Edited by FATGTS-R
The one I mean uses a 40 trim T04E compressor and 50 A/R T04E compressor housing . The turbine housing is integral gate , 58 A/R and V band outlet .
The stumbling block is using large trim T04E compressors on these crossbreed turbos , no way a T3 (small series like we have in Australia) can properly drive them . They create lag down low and the small turbine/housings create restriction not long after the thing gets going . The smaller trim one like this (pics) has airflow more in step with the exhaust gas flow which is how turbos are supposed to be .
Cheers A .
From Clint32's results
The turbo has a 0.6 A/R comp housing with a 54mm comp wheel from memory, this was new. The exhaust housing is 0.6a/r with a 58mm wheel, ,aking 235-240rwkws.
Does anyone know aything about the HKS T04E turbos that came on the cast wastegates and had the external gate for the RB20? For instance could i use this exhaust housing on a GT3076R.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
