"Imagine driving on to a glass road and looking up underneath your tyres. This is the example contact patch (in red) for the situation I explained above. The narrower tyre has a longer, thinner contact patch. The fatter tyre has a shorter, wider contact patch, but the area is the same on both."
Because you now have more space the weight is less per cm so the contact patch decreases. Of course all sorts of factors change this, eg tyre pressure, how much its stretched etc.
Stolen from http://www.chris-longhurst.com/carbibles/tyre_bible_pg2.html
They might stretch them but its not ridiculous stretch eg a 195 on a 9.5" rim.
I don't get this. Sorry to get all technical but it's been done already. I read the the wheel and tyre bible. pretty good info.
So what they're saying is that the contact patch on the road is determined by the weight of the car and tyre pressures already and if you get wider tyres then the contact patch front to back is less because it has more left to right.
Sure but why do race cars have wide tyres then. Don't wide tyres still give more grip?
  • Replies 121
Okay I'm kind of confused now.
When they compare wider tyres to thinner tyres, is this when they put these tyres onto a wheel that's the same width? For example, they put some 205 tyres onto a 6.5" wheel, you get more of front to back grip, but if you put 225 tyres onto the 6.5" wheel you'll get more of a side to side. Is that what they're trying to say?
But lets say if you put these 225 tyres onto a wider rim, like a 7" or even 7.7", would this be more grip than the other because the shaped of the tyre on the ground won't be a rounded shape?
I hope some can understand what I'm trying to say and can explain it better. :rolleyes:
Edited by adam-__-
Yeah ok.
In my head I still think that a 225 on a 7in rim will have the same contact area as a 225 on a 8in rim when the car is standing still.
Even comparing a 205 to a 225 on the same rim, they have almost the same rolling radius and circumference so there is not much change in front to back contact patch. Maybe this small amount is what they are refering to.
Ahh who cares. Wider tyres are better almost all the time. haha...
Wider tyres give you a wider contact patch. So when you're cornering and the tyre flexes, you don't get as much shrinking in the contact patch.
For drag racers, since they run their tyres super deflated, it means you can have more surface area because the tyre doesn't even have to be remotely close to resembling a circle anymore.
That last bit is why, in context, I was wrong. :laugh:
But that's a really good, succinct, graph for what I was thinking of.
anyone know if 234/45/17 can be stretched onto the rear 8.5 inch wide rims?
Stretched?? Are you serious?? A 235 on a 8.5" rim won't even be REMOTELY stretched, it'll still be bulging a bit. Personally I wouldn't use anything more than a 235 on a 8.5 rim. I'd be using a 215.
To SAFELY stretch a tyre and be safe for road use, these are the minimum sizes:
7inch 175/60
7.5inch 185/55
8inch 195/50
8.5inch 205/50
9inch 215/45
9.5inch 225/40
10inch 235/40
10.5inch 245/40
11inch 255/40
11.5inch 265/35
12inch 275/35
You WILL be able to fit smaller tyres, but may not be safe...
Here's a good thread on tyre stretching-
What tyre to fit on a 18x10" rim??
Going through this same sort of dilemma at the moment. I have "x" amount of money to spend on tyres and seeing if its going to give me better grip to run a 255/265 size tyre that is of a cheaper brand or to run a very common sized 235 tyre and buy a decent grippy tyre. If I was to run the 235 stretched I would also be looking at running some "decent" spacers to increase track and therefore one would think increase handling at the same time. The tyres are going onto 9.5" rims on a R32 GTR.
Ryan
  • 1 month later...
probably much of the same thing here but thought I'd see if anyone have ran the following sizes..
I've got 17x8 front and 17x9 rear buddy club P1's
Looking at running 215/45 on the 8" rim and 225/45 on the 9" rim
Who had those sizes?
On my current car, i run 225/40/18 on a 9" rim. We tried stretching a 215/40/18 on there but it was a no-go as it popped off. Needed to be a 45 profile for it to work.
The 215/45 will fit easily on a 8"
lol
thats not stretching, u can run a 235 on a 9.5" rim comfortably.
stretching has its advantages, but none of which have anything to do with making the tire work properly. stretching makes the tire very stiff and means less side wall flex as road tires have weak as piss sidewalls which has been mentioned, this is preferential to a lot of drifters, hence why it became popular in japan. having less sidewall flex means the tire acts more predictably and responsively, which means its often good to fit the the rear on drift cars to allow that response and predictability when flicking the rear around. im currently using a 225/45 on 9.5" wheel for drift, it does make it very predictable, but its pretty shit traction and not really good for anything but drift.
its also a lot about looks, just ask the boys over on ns, it can look tough used right but in the end its not really practical.
ansch: 225 of a 9" wheel will be fine, 235's are probably a better option tho.
7inch 175/60
7.5inch 185/55
8inch 195/50
8.5inch 205/50
9inch 215/45
9.5inch 225/40
10inch 235/40
10.5inch 245/40
11inch 255/40
11.5inch 265/35
12inch 275/35
yep spot on.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
