"Imagine driving on to a glass road and looking up underneath your tyres. This is the example contact patch (in red) for the situation I explained above. The narrower tyre has a longer, thinner contact patch. The fatter tyre has a shorter, wider contact patch, but the area is the same on both."
Because you now have more space the weight is less per cm so the contact patch decreases. Of course all sorts of factors change this, eg tyre pressure, how much its stretched etc.
Stolen from http://www.chris-longhurst.com/carbibles/tyre_bible_pg2.html
They might stretch them but its not ridiculous stretch eg a 195 on a 9.5" rim.
I don't get this. Sorry to get all technical but it's been done already. I read the the wheel and tyre bible. pretty good info.
So what they're saying is that the contact patch on the road is determined by the weight of the car and tyre pressures already and if you get wider tyres then the contact patch front to back is less because it has more left to right.
Sure but why do race cars have wide tyres then. Don't wide tyres still give more grip?
  • Replies 121
Okay I'm kind of confused now.
When they compare wider tyres to thinner tyres, is this when they put these tyres onto a wheel that's the same width? For example, they put some 205 tyres onto a 6.5" wheel, you get more of front to back grip, but if you put 225 tyres onto the 6.5" wheel you'll get more of a side to side. Is that what they're trying to say?
But lets say if you put these 225 tyres onto a wider rim, like a 7" or even 7.7", would this be more grip than the other because the shaped of the tyre on the ground won't be a rounded shape?
I hope some can understand what I'm trying to say and can explain it better. :rolleyes:
Edited by adam-__-
Yeah ok.
In my head I still think that a 225 on a 7in rim will have the same contact area as a 225 on a 8in rim when the car is standing still.
Even comparing a 205 to a 225 on the same rim, they have almost the same rolling radius and circumference so there is not much change in front to back contact patch. Maybe this small amount is what they are refering to.
Ahh who cares. Wider tyres are better almost all the time. haha...
Wider tyres give you a wider contact patch. So when you're cornering and the tyre flexes, you don't get as much shrinking in the contact patch.
For drag racers, since they run their tyres super deflated, it means you can have more surface area because the tyre doesn't even have to be remotely close to resembling a circle anymore.
That last bit is why, in context, I was wrong. :laugh:
But that's a really good, succinct, graph for what I was thinking of.
anyone know if 234/45/17 can be stretched onto the rear 8.5 inch wide rims?
Stretched?? Are you serious?? A 235 on a 8.5" rim won't even be REMOTELY stretched, it'll still be bulging a bit. Personally I wouldn't use anything more than a 235 on a 8.5 rim. I'd be using a 215.
To SAFELY stretch a tyre and be safe for road use, these are the minimum sizes:
7inch 175/60
7.5inch 185/55
8inch 195/50
8.5inch 205/50
9inch 215/45
9.5inch 225/40
10inch 235/40
10.5inch 245/40
11inch 255/40
11.5inch 265/35
12inch 275/35
You WILL be able to fit smaller tyres, but may not be safe...
Here's a good thread on tyre stretching-
What tyre to fit on a 18x10" rim??
Going through this same sort of dilemma at the moment. I have "x" amount of money to spend on tyres and seeing if its going to give me better grip to run a 255/265 size tyre that is of a cheaper brand or to run a very common sized 235 tyre and buy a decent grippy tyre. If I was to run the 235 stretched I would also be looking at running some "decent" spacers to increase track and therefore one would think increase handling at the same time. The tyres are going onto 9.5" rims on a R32 GTR.
Ryan
  • 1 month later...
probably much of the same thing here but thought I'd see if anyone have ran the following sizes..
I've got 17x8 front and 17x9 rear buddy club P1's
Looking at running 215/45 on the 8" rim and 225/45 on the 9" rim
Who had those sizes?
On my current car, i run 225/40/18 on a 9" rim. We tried stretching a 215/40/18 on there but it was a no-go as it popped off. Needed to be a 45 profile for it to work.
The 215/45 will fit easily on a 8"
lol
thats not stretching, u can run a 235 on a 9.5" rim comfortably.
stretching has its advantages, but none of which have anything to do with making the tire work properly. stretching makes the tire very stiff and means less side wall flex as road tires have weak as piss sidewalls which has been mentioned, this is preferential to a lot of drifters, hence why it became popular in japan. having less sidewall flex means the tire acts more predictably and responsively, which means its often good to fit the the rear on drift cars to allow that response and predictability when flicking the rear around. im currently using a 225/45 on 9.5" wheel for drift, it does make it very predictable, but its pretty shit traction and not really good for anything but drift.
its also a lot about looks, just ask the boys over on ns, it can look tough used right but in the end its not really practical.
ansch: 225 of a 9" wheel will be fine, 235's are probably a better option tho.
7inch 175/60
7.5inch 185/55
8inch 195/50
8.5inch 205/50
9inch 215/45
9.5inch 225/40
10inch 235/40
10.5inch 245/40
11inch 255/40
11.5inch 265/35
12inch 275/35
yep spot on.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
