  • Replies 54
i already had all the parts, just needed someone to piece it together
since when do u have a misfire problem and budget $2k for it?? obviously your not telling us the whole story. i get my car tuned there and tom is nothing but helpfull.
If they wouldnt touch your car then im sure it was for good reason, you make it sound like they wouldn't just because they wernt in the mood.
yeah like I said I never had anything major done there, but the times I have dealt with them they were great. one example. about 5 or 6 years ago I needed a harness for an HKS turbo timer, BD4s were the only ones who had it. My old man went and picked it up for me (cheap part, maybe $25) and Paul asked him to wait for a minute, went back into the shop and pulled out an english copy of the user manual for the thing (about 20 pages) and it was spiral bound and covered etc and just said, here take it, you might need it. I thought that was nice.
I found Paul, (Mr Bd4's)
just by chance the other day i ran into him, he and his mechanics are working out of carline mufflers just down the road, 25 higginbotham rd Gladesville , you can contact him on 98075145
Edited by 33drifter
i was talking to my good friend about this subject and how people are making a big deal of it so i showed him the post people have made ,he laughed his head off because he knows these guys well really well he was there many years ago working as a mechanic well be for most of you guys probably had license ,somethings people have said early in the post is true but most of it is crap.(his words not mine)he told me what happen and from my understanding it was a long time coming unfortunate but necessary . there is a moral to the story but he wont let me tell it.(long live the memory of bd4s) :P:)
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
