I put a set of BrakeWests ADR approved hoses on my GTR and there was a noticable difference.
The pedal feels much solider and you only need to tap the brakes before the brakes start working.
I've got a group buy going on at the moment.
$195 for a full set of ADR approved hoses delivered!
http://www.skylinesaustralia.com/forums/in...howtopic=177690
  • 3 months later...
I paid $315 for the brake lines only. Whats a clutch line worth these days?
If you aren't too fussed about ADR's then i reckon the nismo ones for $250 delivered on nengun are the way to go if you aren't in a hurry to get them.
Dave,
I got a quote off them for $445.00 for braided brake lines and clutch lines delivered.
That a good price people?
I'd just wait for the group buy to start up again. $195 delivered. Unless you are in some sort of rush?
www.braidedhoses.com.au is all you need to know.
This site will tell you pro's con's where to buy them etc etc.
Unless the braided line has the little rubber grommet between the banjo/fitting and the braid it is not ADR compliant.
After the hoses are made they are tested to 3000psi to ensure no leaks, then if possible9 by that i mean room permits depending on the fittings) they can be stamped to say that they have been tested and comply and the company that made the hosed is required to keep documentation on the job it has completed in case of problems down the road. Its amazing to see just how much the rubber lines balloon when placed under 3000psi of pressure, in braided lines there is zero expansion.
I have them on my bike and on my car and the difference is very noticable and I think well worth the money.
They are over kill on a clutch pedal unless its running near something extremely hot, exhaust turbo, replacing the stupid system on an R33 with a single rubber line and doing away with the other bits of metal piping, is well worth it as they're a pain to bleed sometimes.
I can see a point of view that they are not needed on the road unless you drive like an idiot, however, remember that the energy that is used to balloon your rubber lines instead of stopping the car, unlike braided lines, could be the difference between a close call and an accident. The same applies for the master cylinder stopper ( these are standard on VS commodores and maybe some others I think).
Edited by mattymagoo22
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
