  • Replies 108
Hmmm - I think I'll struggle to make 6:00pm - but can try. 1st movies starts at 7:30 right - so yeah, 6:30 would be the absolute latest.
I've not been to the drive for like 20 years (last time was to watch Star Wars when it forst came out - that was tops)
Do the movies start right on 7:30 sharp ???
WHat route do you suggest, in case people can try to catch up along the way ??
Carlo - BK TH is actually still there, physically, but it has closed down.
Eeewww... Just thought that my battery wont be able to handle 4 odd hours of stereo time without the engine going...
Do they still have the speaker things you put in your window instead of tuning your radio into sound? You know, like the one that flips the Flintstone-mobile in the start of the cartoon? :)
KNAT - I was thinking they should have a set of jumper leads coming out of the side, instead of the standard speaker...
Or more realistically, a trickle charger cord you can plug into your cig. lighter to give you more time...
Anyone know a safe way to pull off the rear-vision mirror and/or bracket ? hehe
rahahahaha
/end evil laugh
I've got the best rice in store, the prize will be mine :(
See you guys for the first movie....Dan do we need to tell them we are from SAU at the gate?
BTW, top sig toulia, I just got another mortgage, and I reakon you're right, they would notice if i died :(
Yeah Duncan,
I think that it would be the way to do it, I don't think they would care if you said "I'm from the WRX club!"
To tell you the truth though I think that carlo might be better at answering this one.
So, the list above, is that list based on the assumption that each individual person listed is coming in a seperate car?
If one on that list decides to get a lift with someone else instead of driving, is that a problem as far as the movie people are concerned?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
