Hi there,
just wondering if i could get peoples advice, i was in a small car accident this weekend. now i was not at fault in the accident.
I think i have hurt my neck in the accident, as it feels sore and hurts when i move it. How do i go about claiming my injury? Do i go to the doctor and get a report and then submit that to the insurance company so that the person at fault can pay for any medical bills?
Thanks Michael
edit: i am with just-cars insurance if that matters
personal injury insurance is covered under your compulsory 3rd party personal injury and registration that you pay on your vehicle. You wouldnt claim it through Just Cars.
Its a claim you make through the government. im not 100% who you actually speak to, but if you call DPI on MOnday im sure they could tell you as they deal with rego and licensing etc.
Edited by _8OO5TED_
first things first is to go to a doctor asap and tell them the full story and report all the aches and pains etc your feeling so its all down on record.
Im not 100% sure who you claim it through but you can get a nice amount of compensation for it.
let me know how you go michael, however i'm going to ring the DPI monday too..
i still have a sore neck from my crash, and i should really have rang the DPI earlier, i did go to the emergancy department straight away though, and let them know it was a motor vehicle accident.
money for car mods would be good. :P
Yeah, the problem with this kinda things is, it might not hurt bad now.. but down the road it might just suddenly haunt you. I don't know about the aussie system thou, but regardless, go to a hospital and get a full x-ray and mri just in case, and find someone to claim. Good luck and take care mikey. Hope u're feeling alright. Was the line involved in the accident?
P/s: Mitchy, has it landed and registered? :P
Go to the doctor as soon as you can.
They'll give you a form to sign and probably refer you to a physio, they'll give you an incident report to fill out.
You'll also need to report the accident to the police as there was someone hurt and the insurance form needs a police report number.
I was rear ended at the end of feb and my neck didn't hurt too bad, went ot the doctor anyway. Lucky I did as I had some damage to my neck and shoulders, was all covered by their rego insurance.
Yeah if you obtained an injury during the acident your supposed to ring the police within 24hrs else there's no real way of determining if the accident caused the injury.
ps. you get my reply Michael about my dash, I wasn't sure if it send or not :)
like people have said go to the cops asap. my mrs was hit by a car and busted her leg up pretty bad. go to the cops and they give u an incident report sheet to fill out.
give them all the details of what happened and who was invoved and the cops sort it out from there.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
