Hi guys, thinking of rebuilding my rb25 neo to handle 330-350rwKW
what i have so far--> gt3240, external gate, 600cc injectors, pfc, fmic and all.
on the card--> tomei poncam, cam gear, custom plenum & throttle body.
whats required in a minimum rebuild to handle this sort of power? this is gonna be the last major mod for my car to keep me entertained till I have saved enough for a r34 gtr, therefore a basic rebuild is all im after.
many suggested forged pistons is a must. also metal head gaskets.
what about valve springs and retainers?
what else do you think i need?
thanks for the help.
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/174833-rb25-neo-basic-rebuild-for-350rwkw/
if your rebuilding get some forged pistons, gtr rods, a good brand (ie trust) thick metal head gasket, n1 water and oil pump, acl race bearings, gates timing belt, oil cooler, q45 afm, decent ebc (not essential but with that power its great to turn the boost down when required). A decent clutch, maybe a diff, splitfire coils. thats just off the top of my head, still wanna go through with it lol. lotsa cash basically.
If intending to run more than say roughly 20psi valve springs as some have experienced valve float above, rods you can pick eagles up for cheap these days Diff is non-essential but wouldnt hurt, gear set some have seen past the 400 mark some havent its touch and go there add power increase wear. Part from that the above post is a good start :P its a fun and expensive game.
If you add the handling to it, theres more money and braking a little more money.
Cheers
check, check, check. also already has greddy ebc and z32 afm. is q45 afm necessary for the power level?
and I thought r34 gtt came standard with gtr rods?
I thought I have read somewhere in this forum that rb25 neo came standard with gtr rods, guess i was wrong then.
what about water and oil pumps? the standard ones are good for 300rwkw, do they really need upgrade for an extra 50kw?
GTR crank, rods & forged pistons of some description
Either way there is no such thing as a basic rebuild when chasing 350rwkw :thumbsup:
Its going to cost you around 6-7k.
whats the breakdown for the 6-7k, including labour I assume? I already have all the external supporting mods as said above.
cheers
ye thats labour, motor in out etc etc. a 26 crank alone is ~$1100, pistons $1300, motor in/out $1000, so you can see the costs going up quite fast :)
Doesnt include tuning or any extra head work, just a light tidy up of the head and what not.
So if you wanted the extra gear like springs etc, then add accordingly
That GT3240 may be a bit of overkill and have manifolding issues because only HKS had exhaust housings made for them and they are 0.87 A/R and T28 mounting flange . A T3 flanged GT3037/GT3076R would probably be a bit more responsive for the power .
Cheers A .
ye I know its an overkill as I could only run low boost with standard internals, was considering down sizing for more response but want get the rebuild under way first and see how it turns out.
Still never pulled a NEO down with GTR rods,Every engine sofar has had std RB25 rods.Dont use R33 Forged pistons,Big mistake that I see from shops that should know better.
If you are regularly pulling down NEO engines then why don't you take a pic of the rods you pull out, maybe put them next to some RB26 ones. Even better take some measurements.
You are the only person I know still saying that they don't have GTR rods in them. The part numbers are even the same for all the GTR's and the NEO RB25 in FAST.
I will have to admit that I did not personally view my own rods however I gave my engine builder some R32 GTR rods to replace them and he said that when he put them side by side they were identical. I can't think of any reason why he wouldn't use the GTR rods supplied if they were different.
As for putting on an oversize turbo then turning the boost down - have a think about what you're saying dude. 350rwkw from an RB25 is going to be laggy with the best possible turbo so why the hell would you introduce more lag deliberately. If your answer is "i'm getting a really good price" then sell it and get something more appropriate.
I can't comment on valve train because I only run about 19-20 psi but maybe you should look at some slightly bigger cams like the Tomei Procams.
I don't think you need a GTR crank as you can get a crank collar fitted to deal with the small oil pump drive issue which should be enough. Jun oil pump? (There goes a grand) N1 water pump.
Basic rebuild for 350rwkw? These two terms don't belong in the same sentence together.
Bloody oath they are a must. I use Wiseco pistons because they are teflon coated from factory and have long skirts which I believe helps keep them straight in the bore thus less long term wear which probably doesn't matter to you. Any pistons for RB25 will fit the NEO.
If I was rebuilding again I would look at coatings for lots of the moving parts like bearings and so on.
A 3.5" exhaust would be helpful but a quality 3" one will do the job.
A good diff will be essential. What have you got?
Tyres?
What kind of intercooler do you have? Do you think it's capable of it's new job?
Like many have said, there is nothing "basic" about building a rb25 to make 350rwkw.
Its not a matter of buying a bunch of parts and slapping them on and voila 350rwkw appears.
Your car will be off the road for some time and unless you can learn how to put an engine together yourself (its not that hard) dont expect change from 20-25k if your going to go all out.
And really, whats the point in under taking such a project if your not going to do everything the right way the first time?
seriously, consider a RB30 bottom end. you can get the motor built, then change it over later (less time off the road) and you can buy an RB30 cheap, and full forged rebuilds are cheap(ish) becuase everyone with a VL turbo has one. this owuld also do miracles for the larger turbo
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
