hey guys, im hitting the drag strip in a couple of weeks for the first time.
car-->98 gtt, 260rwkw @ 1.1bar, gt3240, single heavy duty clutch, front 225, rear 255/40/17 bridegestone re050.
turbo is set on relatively low boost because of standard engine internals. the car gets plenty of wheel spins both first and second gear on the street. so at what rpm should i launch the car? any advantages launching it on second gear to limit wheel spin?
should i ride the clutch or dump it?
what tyre pressure do I use? 30psi front, 22psi rear?
do i need to do a burn out? whats a good burn out technique to warm up street tyres?
as its a quite powerful car for a drag racing noob like me what other precautions or things that i should be aware of?
thanks for the help
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/174958-260rwkw-first-time-drag-techniques/
thanks for the help
do not launch in second...it will put too much pressure on ur car....wheel spin means less pressure on your car, and as long as its not too much wheel spin u will get off the line alot faster then no wheel spin.....u will more then likely bog down.
launch at 4 grand and see if you just sit on the spot, hopefully the car squeals and takes off....if u spin topo much bring it down a bit but i have noticed that 4 grand is good for me on street tyres. dont ride the clutch, but prob dont just drop it....but id say more drop it then ride it....
front normal tyre pressure and rears sound good.....definitely do a burnout....best way to get heat into the tyres....no burnout means u will be doing ur burnout off the line....
where abouts u from? where will u be going?
Little point in a burnout with street tyres, i've found heating them too much hinders.
I ran a 12.9/109mph with 220rwkw. 2.10 60ft, so not the best being my best laugh was 1.9 60ft.
You will get wheelspin, impossible to not, you just have to make clever use of the clutch and power at the same time to have the least amount of it (wheelspin).
I'd say starting off around 4000rpm and see what works, whats too savage and what isnt.
Either way its gonna be hard.
I also ran a 12.1 with over 300rwkw, wheelspin no matter what i did to 1/2 track hehe. So with 260 you might be able to pilot it to a mid 12 on street rubber.
I really should get something bigger than 225's for my rear :domokun:
thanks guys.
hmm..no burnout means u will be doing ur burnout off the line....while heating them too much hinders.. maybe something in between, a light burn out? how do you do a light burn out?
re 60ft time, is around 2 secs to be expected for a rwd car? i mean if more than 2.2 then i must be doing something wrong?
lol 225s are really too tiny for anything more than 200rwkw on tap :) A factory standard Porsche Boxster S gets 265/18 and only 165rwkw. Edited by BaysideBlue
yeah dont cook ur tyres but def some sort of burnout......light them up in 2nd and roll out....no braking....that should do it....
good 60ft for street tyres for a beginer is realistically 2.2....anything under that you got to be happy with.....i average a 2.1 on my 19" by 275....my best on them was 2.08....best i have done on street tyres is 2.025 but they were T1r's on stockies....
  • 1 month later...
sorry to hijack the thread a bit, but what if you have a clutch that doesn't allow for slip, im running roughly 200rwks on 225 toyo's. what would the best rpm to launch and how should i control the accelerator.
my fastest 60 ft so far is 2.23 but i know it can be faster, i just cant seem to get the traction off the line
any pointers would be much appreciated
cheers
do a decent burnout... use tyres with a good sidewall.. something like a 225 with a 50 sidewall so u can deflate them or a killer compound 255 tyre.. which you already have..
take off with no more than 6,000rpm and go easy on the clutch dont dump it..
i ran 1.9 60 footer on 205/55R15 $50 dollar tyres i got from newlands rd 2nd hand tyres
13.1 1/4 with 205kw
and a killer burnout..
Regardless... You need heat in ur tyres
thats interesting.
as my first time out, saw me doin a burnout the first 2 runs. then a rather experienced drag racer told me, "try not to do a burnout next time, as the street tyres perform worse hot". And as he said, I didnt do a burnout, and ran my PB time so far.
Edited by silverbulletR33
depends on tyres, some cars will launch better on cold rubber.
i dont see why your making all this effort to allow for crap tyres, when buying some decent ones will probly result in your best $ vs. gain on the track. why is everyone so dead set on getting big power when you cant even put it down properly?
a set of stockies is like $50 for 2 R33 rims? i know decent tyres arent cheap but for what you can gain, why not? have a spare set of rims/tyres for the track?
LTHLRB, damn good times for that power/tires. you've done well mate
No it's not a Skyline link, yes it's for a Supra, but again, most of it still applies (Bar how to directly adjust suspension stuff)
http://www.supraforums.com.au/forum/showthread.php?t=18639
And EUG, your bug gets me everytime! nearly everytime I go to wipe my monitor!
if you can select low boost for take off then do it.
try and slip the clutch and dont mash it off the line. it takes some practice to find the balace of slip and bogging down. but best thing is to get out htere and have a go :) and get a feel for how your car behaves.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
