So fellas,
Most of all - if not all, have seen the awesome new action-packed flick, Transformers movie - the motion picture, right? That's great - good stuff... guess what, for those that do not know, there was a Transformer named "Side-Swipe" that's actually a R32 GT-R Skyline in the original Armada series. How cool is that?
Check out the pics & information below!! Please post more pics and info if you can find them...
Scroll to the bottom of the page...
http://en.wikipedia.org/wiki/Sideswipe
So fellas,
did you try explain that to the cops when they pulled you over to try and get out of it?
WWWWWWWWWWWASTELAND!
So fellas,
found this....
ha ha ha... if I had a transforming Skyline, I wouldn't have to explain anything to the cops at all.
Cheers,
"I'm sorry officer let me just get my license for you...... after my GTR RIPS YOU A NU WAANN" ;)
I can see my GTR's hydrolics failing when its need most....
"I'm sorry officer let me just get my license for you...... after my GTR RIPS YOU A NU WAANN" :bunny:
ha ha ha... actually - well, one things for sure!! If a transformer Skyline was driving down a freeway - the cops would give it a canary for sure... LOL, or would they? (wink wink).
I don't know about you guys, but I've already ordered (from my friend he is a vinyl, sticker, badge maker) 3 Autobot Badge-like stickers for my black R33 Skyline - one with go at the back where the GT-R badge usually is located and the other two will be located use under the side indicators on both sides... should look hot as - anyone thinking of doing the same??
If so, would you badge your car as an Autobot or a Decepticon???
Autobot - nobility, to protect and fights for justice
Decepticon - ruthless, evil, crazy-arse fighters who fight for domination
Your call - choose your side, Soldier! :bunny:
http://endingnew.blogspot.com/2007/06/more...ineleisure.html
Edited by Spunky Munky
Your call - choose your side, Soldier! :)
WTF? Another quality comment! :bunny:
Dude - you have outdone yourself with this one
Its still not the orginal transformers sideswipe was a red ferrari I think??? Armada is not old school enough!
Sorry my mistake just checked it and he was a red lambo He was my favorite along with sunstreaker
Edited by smurf80
I have a transforming GTS-t. I've had a decepticon sticker on it for agesssssssssssssssssssss, at least 2 years... yes Fan Boy... I know :bunny:
At night, when no one is around... sometimes it transforms and runs around and stuff..... no seriously.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
