Just a thought if a custom parcel shelf is made is it possible to fit one (if your crazy enough 2) 10 inch sub there?? Just a thought. Cause if it is then splits up front and sub(s) in parcel tray would be awesome for someone who doesnt want to put subs in boot. Is it at all possible or is it just a pipe dream???
https://www.sau.com.au/forums/topic/175523-sub-in-parcel-tray-possible/
trying to think is it even big enough for a 10".....it be a tight squeeze....id say 2 is out of the question....
unless u put a tilt on them.....but that will tough...either restrict vision and be above or burry them....
cool cool, just wondering cause a mate of mine is selling his 10 inch pioneer sub there the free air bullet kind. So i started wondering. Splits up front for nice treble and a 10 inch in the tray for added bass. anyone out there know of someone who has attempted this?? or whether its a feasible idea.
Edited by LatinR33
pull the seat out. look at it from a different angle. a 10" sub will go in BEHIND the seat BUT you will need a LOT of power and the ENTIRE boot will need to be sealed off from the car for it to work.
sub on the rear shelf - no. depth for one legality 2nd,
hey i had 2 8inch subs and a set of splits in my old custom backself need to watch out for all the stuff under them though dont forget i think you could put two 10s in there as long as they where shallow mount if they where not you would have to think about getting a small battery you can mount on its side. definatly do able and sounds fine
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
