Just a thought if a custom parcel shelf is made is it possible to fit one (if your crazy enough 2) 10 inch sub there?? Just a thought. Cause if it is then splits up front and sub(s) in parcel tray would be awesome for someone who doesnt want to put subs in boot. Is it at all possible or is it just a pipe dream???
https://www.sau.com.au/forums/topic/175523-sub-in-parcel-tray-possible/
trying to think is it even big enough for a 10".....it be a tight squeeze....id say 2 is out of the question....
unless u put a tilt on them.....but that will tough...either restrict vision and be above or burry them....
cool cool, just wondering cause a mate of mine is selling his 10 inch pioneer sub there the free air bullet kind. So i started wondering. Splits up front for nice treble and a 10 inch in the tray for added bass. anyone out there know of someone who has attempted this?? or whether its a feasible idea.
Edited by LatinR33
pull the seat out. look at it from a different angle. a 10" sub will go in BEHIND the seat BUT you will need a LOT of power and the ENTIRE boot will need to be sealed off from the car for it to work.
sub on the rear shelf - no. depth for one legality 2nd,
hey i had 2 8inch subs and a set of splits in my old custom backself need to watch out for all the stuff under them though dont forget i think you could put two 10s in there as long as they where shallow mount if they where not you would have to think about getting a small battery you can mount on its side. definatly do able and sounds fine
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
