Just a thought if a custom parcel shelf is made is it possible to fit one (if your crazy enough 2) 10 inch sub there?? Just a thought. Cause if it is then splits up front and sub(s) in parcel tray would be awesome for someone who doesnt want to put subs in boot. Is it at all possible or is it just a pipe dream???
https://www.sau.com.au/forums/topic/175523-sub-in-parcel-tray-possible/
trying to think is it even big enough for a 10".....it be a tight squeeze....id say 2 is out of the question....
unless u put a tilt on them.....but that will tough...either restrict vision and be above or burry them....
cool cool, just wondering cause a mate of mine is selling his 10 inch pioneer sub there the free air bullet kind. So i started wondering. Splits up front for nice treble and a 10 inch in the tray for added bass. anyone out there know of someone who has attempted this?? or whether its a feasible idea.
Edited by LatinR33
pull the seat out. look at it from a different angle. a 10" sub will go in BEHIND the seat BUT you will need a LOT of power and the ENTIRE boot will need to be sealed off from the car for it to work.
sub on the rear shelf - no. depth for one legality 2nd,
hey i had 2 8inch subs and a set of splits in my old custom backself need to watch out for all the stuff under them though dont forget i think you could put two 10s in there as long as they where shallow mount if they where not you would have to think about getting a small battery you can mount on its side. definatly do able and sounds fine
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
