I have a garrett journal bearring t3. It *might* be a super 60 but I'm not sure about that.
.60 AR Compressor housing
.48 AR exhaust housing.
Garrett claims 350 hp on they're current t3 with a .42 AR compressor housing.
I'm just curious, as I broke a plastic tip off of one of my 450cc injectors, what sort of boost should I run with this new turbo on the factory injectors? I have an SAFC, HKS EVC, and will be using an AEM wideband.
At this maximum safe boost level, what horsepower should I be making? My goal is 300 whp, but I figure that might be pushing it too far.
Thanks!
-Max
https://www.sau.com.au/forums/topic/175729-factory-rb20-injector-limit/
Its dependant on airflow
Its not a "given" psi. One turbo might will flow more than another, etc etc.
So using "18 psi" is a load of rubbish :thumbsup:
Depends on the car/turbo spec and carry on from there
cheers
This is why I listed the specs on my turbo, and injectors...
I'm not looking for an exact answer, but just a safe guestimate..
Thanks!
with my t3/t4 turbo i got 327hp with stock injectors and a cheap FPR. Injectors reached 100% just before redline and a/f's went to around 12.7-13:1 can't quite remember.. the turbo has a .63 exhaust and a .5 or .55 front again can't remember. this was with an safcII aswell. And also 18psi
Good to know, I dont want to reach quite that high of a duty cycle, but I also have a smaller turbo than you...
I'll keep the boost around 16 psi and maybe take my fuel pressure up a few PSI.
Thanks for the response!
PS: do you have a dyno graph? and did you add fuel with your SAFC?
yeah got a dyno graph i'll scan it and put it up. but it only have power against boost, no af. we actually had to take out fuel over most of the map as the factory computers just dump the fuel in as a safety measure. we tried addiing more fuel at the top but it didn't help which is how we know its the injectors. set ur fuel reg to 40psi as the base pressure. i ended up turning mine down to about 15-16psi on high boost for the street just to be safe
thats with the vacuum line unplugged correct?
My guess is that this is with idle vacuum, and a rising rate reg.
Seriously, i dont see why you guys dont spend the $200 and upgrade to gtr injectors, its a small % of what you are spending doing it up, and than skimping on the most important part
I have a lot of difficulty believing rb20 injectors can flow enough for 327rwhp. regardless of rail pressure. also you do not want to run a rail pressure of any higher thn 60 psi due to o rings and hoses that are 15 years old (44 psi + 16psi boost) even if you did run 4 psi extra rail pressure that is less than 6% more fuel and 270cc equates to 273.5 horsepower at the flywheel then add 6% and you get 289.9 horsepower at the fly wheel at 12:1 afr.
then you have drivetrain loss to consider:)
I am not trying to start an argument but there are the calculations for you.
to keep it simple, 200rwkw is the maximum i would want to run on RB20 injectors!
On Boostworxs dyno myself and a mates both hit 100% duty at around 180rwkw with a 12:1 afr and stock fuel pressure.
Mate of mine was running a suspected GTR pump that later ran out of fuel at 250rwkw and my own which is a bosch 044.
180rwkw is 241rwhp so 29rwhp drive train loss going by the usual 270cc injectors = 270hp. :S
Maybe our beloved DD Dynos are reading a touch high as technically its not possible for 270cc injectors to make 241rwhp when you consider drive train loss.
Was the 250rwkw with stock injectors with a stock FPR?
Sorry no. His stock injectors with the same fuel pump and stock fuel reg hit 100% duty at ~183rwkw with 12:1 afr's Gt35r .82 on 7-8psi.
Dropped in a set of sard 800 twin sprays maxed out the fuel pump at 250rwkw and then went on to make 260rwkw on 1 bar.
The turbo really didn't make all that good power under 10psi; over 10psi it really woke up.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
