I don't have that problem, but I do have a problem which is I cannot see what feedback I have left for other people (and I also can't see what feedback other people have left their trades).
Yeah I get that too. The URL for that missing image comes out as "http://www.skylinesaustralia.com/forums/{ipb.vars[" - and occurs on all skins (I'm using IE6).
Regarding BB's issue, this is what I see
Viewing BB's feedback (works)
http://www.skylinesaustralia.com/forums/index.php?act=tradecom&CODE=user&mid=3621&la=0
Viewing feedback made by BB (doesn't work)...
http://www.skylinesaustralia.com/forums/act=tradecom&CODE=fromuser&mid=3621&la=0
...it's missing "index.php?" in the URL, i.e. it should read:
http://www.skylinesaustralia.com/forums/index.php?act=tradecom&CODE=fromuser&mid=3621&la=0
If you paste that URL into the browser, it shows the feedback made by a user, however, all the links below the page heading (i.e. to PM a user or view their trader history) has errors in the link so they won't work.
you are a freakin genius. :dry:
I also notice if I use the link you posted (it works I can see what feedback I have left) but if I click on the 'return to beer barons feedback' link I get the 404 not found again. so that link must be broken too.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
