  • Replies 134
dude its not very hard.....ya just have to set it up the right way and SHA-BANG u got a perfect drifting car capable of doing anything.....if i get another memory card i would be interested in mailing it to u if u feel comfortable send ur address to me!
that 180 is still very very fun to drift.....all i am saying is that the esperante is just damn fun to drift.....i know that it seems like its not possible but trsut me it is.....it gave me sall the experience i have today and made me the drifter i am right now....all i got to say is that experiment with cars that u wouldnt think of being really good drift cars........like take a italian car out there or a mercedes-benze......or if ur really gutzy.....take out a formula 1 car out there.....hey i would really be interested if u guys would want to try that out with me....hell it'll be a "project car" i mean the can haul ass and they get tire smoke fairly easy so i mean hey i think they can be drifted!
hey would u guys be interested in doing some top speed, 0-400M, and 0-1000M times/runs? cuz i was messin around with the mazda 787B and got it to do 257.0mph.....and i got a Lotus Espirit V8-SE to do 268.6mph.......so if u guys would like to try and beat those then go for it....but fyi i havent even gotten the escudo to beat that espirit in the top speed.....i cant remember my 400 or 1000 Meter times but i will get them up here....so if u guys are interested let me know by emailing me at [email protected] or just post it here.
  • 9 months later...
I think we should upload some of our own GT3 drift videos. I use an old S13 Silvia, with very similar settings to Rezz and it kicks ass, it's all technique and power balance, to much sucks. Ill try make a video of my drift when i get home. :(
Yes, i've lost my license. I have nothing else to do!
I think we should upload some of our own GT3 drift videos. I use an old S13 Silvia, with very similar settings to Rezz and it kicks ass, it's all technique and power balance, to much sucks. Ill try make a video of my drift when i get home. :)
Check the other thread... ;)
  • 5 weeks later...
  • 5 weeks later...
to get the toms chaser win the amateur altezza race.
i have fun with a s15 on specialstage 5 wet.
who knows the trick with the suzuki escudo where you can get it over 1000kays?! (yes im serious, and i can prove it)
My "tuned" Mines GTR doing some low speed and high speed drift.
I can get it to do some 500km/h powerslides, but to truely control it I gotta make it stay on the rev limiter on 2nd gear at about 150km/h
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
