Hey guys,
Long story short: I own a R32 GTS4 rb20det moderately to highly modified, about 2-3 months ago i damaged the engine, we think its a head gasket but havent pulled it apart yet. I have been more keen to get my RB25det in! So anyway, when i blew the engine a few months back, we rolled it and stored it at a friends place near by. Last night we were finally able to bring it home!!! so happy to see it again!!!!!!!!!!!!!
ANYWAY, the rb25 hasnt been rebuilt or anything it came straight out of a staggy half cut with low K's so im keen to just throw it in. But there is one precaution i would like to take and that is replace the OEM head gasket with a metal one to help prevent blowing another one too soon. This will be done by me and a friend so just wondering what were the 'technical' aspects about this project... ive heard you have to undo the bolts in a certain sequence to prevent bending the head as it comes off? Anyone know this sequence?
Any extra info would help :blink:
Cheeeeers
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/
cheeers guys! ripped the RB20 out this morning! so now its time to start preping the rb25 for the drop in.
I dont want to push anything over 240rwkw now as i want to keep a bit of reliability/streetability, id be more than happy with the more responsive and torquish power from the 25 after driving the 20. All the parts i have are interchangable between the engines except for: Jun front fed Plenum, custom fuel rail, and GTR injectors. Trying to figure out if i should go stock 25 plenum and pay for extra cooler piping or buy another front fed plenum to fit the 25...
So now its time for my shopping list... Would love for some input. (Trying to keep to a budget and only getting what i NEED for this to work.)
The RB25 shopping list: (So far...)
- Head studs
- 555cc nismo injectors
- Metal head gasket (What size is recommended for say 14-15psi of boost.)
- Gasket kit
- New belts
- New hoses
- Oils and fluids
Edited by zertek
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/#findComment-3230470
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
