i was "Driving Swiftly" down a lane cause we were in a hurry. and i saw something that scared me, i hit the brakes but it was too late. a huge drop infront of my sent the skyline on an angle and the awful sound of a grinding front spoiler made my teeth shatter.
i have owned the car for 2 weeks and have now scraped it. there is no real damage, just some scratches on the underside. but it made me think and i put the question to people who have to deal with the same kind of problem.
how do you deal with such a low bumper, and how durable are they :S
can they take the occasional knock?
Edited by finster
https://www.sau.com.au/forums/topic/176767-front-spoilers/
it also depends on how many times it has already been repaired too. body filler will just chip away even with the slightest touch. you can also buy the flexable bumpers, i seen them in a magazine, mind you they would be pricey. bumpers have a limited flexability as paint has near none. in many cases the bumper will flex and the paint in that area will tend to come away over time...
https://www.sau.com.au/forums/topic/176767-front-spoilers/#findComment-3231804
Mines scratched slighjtly underneath, Skylines seem to have a bad turning circles (like many other Jap cars) as opposed to bigger commodores.
The best advice i can give you is "take your time when turning, doing u turns, going over bumps etc...
https://www.sau.com.au/forums/topic/176767-front-spoilers/#findComment-3232081
dont worry mang.. its learnt reflex and instinct lol
before you know it you'll be dodging potholes without even thinking...
and esp on your usual routes u'll know where they are.. i always stay out of the lane if i know tehres a bump coming up
+1
https://www.sau.com.au/forums/topic/176767-front-spoilers/#findComment-3233414
as far as bumper flexability goes you can get a flexible primer (undercoat) to help prevent fractures in the paint...
Thats what I did although its better for stone chips than anything else...... I am having the car completely resprayed and at the same time they are making me a mould of my front bar and making an extra two (current one has been repaired too many times previously - previous owner + 1 is mine). This way both the other bars will be ready and waiting - they are also giving me the mould to keep so I don't see every other 33 in the area with the same bar :domokun:
The cost of the two new bars + the mould is $650. Pretty cheap considering the cost of replacing/repairing and I can use it on any future skylines or sell the mould to a friend with the same bar ;)
https://www.sau.com.au/forums/topic/176767-front-spoilers/#findComment-3233507
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
