ummmm I don't know what to say except...
YEAH BABY! now we are talking.
I assuming it's built for aus sports sedan series? looks good. what look like penske shocks, and obviously the full tube chassis and mid mounted engine are hard to miss! is it going to be running a 4 or 6 when done? bit hard to tell from the pic but I'm guessing an RB of some kind? maybe 26/30?
Yes it is for the National Aus Sports Sedan Series and will hopefully be completed by the end of this year.
Motor will be the RB25 that is currently being run in my DR30 with a much wilder tune than current. Using the RB25 due the multiplier factors to work out final capacity as we think the weight should come in at 950-990 kg with driver. Yes they are Penskes all round.
All I can say is I dont think I will ever ever take on a project like this again but it is so far past the point of no return that we just keep on going.
Car has been designed and built with only one purpose and that is to hopefully beat Tony Ricciardello in his Alfa Chev. A very big ask but we are going to try very hard.
well good luck, it looks awesome.
tony will be tough to beat as he has been campainging that car for so many years now he has it set-up pretty well. but I've no doubt you will have a damn good shot. It looks like an awesome package to me. who desinged the car?
I was doing some laps at a practice day at oran park gp a month or so back and Kerry Baily was there with his Z with glenn seton doing the driving. had a good close look at his car and it is very impressive. pretty sure phil ryall built that car.
masterstroke of understatement there richo.. :bunny:
Maitland Performance Fabrications designed and built the space frame, hubs and cage. Fantastic workmanship and attention to detail but boy do you pay.
Under no illusions that Tony will be easy to beat...close to 30 years of car development and history have gone into his current car as far as I am aware. We are concentrating every part of our efforts on achieving maximum driveability and power down characteristics because if there is one thing to see in the Alfa Chev it does not matter if he is on or off racing line the car just squats and goes, however having raced against him in different classes his car is not quick at just before corner apex and just after...it is when it straightens up that it puts every bit of power to the ground.
Thanks for the comments...the photos don't really do the car justice.
Chhers
yep, it certainly looks top shelf.
no doubt tony's car has awesome drive out of corners I tend to agree too that mid corner may be where it falls down a bit. well I hope it comes of well, and keep on truckin! I can imagine the time and money into so far must be hard to take, but it will be awesome on track.
LOL...i have been so waiting for you to ante up and post pics of your car. Its so different and so waaaay cool! The turbo is bigger then my diff! :rolleyes:
LOL, we shoudl have done Dutton in it. We woudl have flogged all comers in the standign 1/2 mile :D
...oh and it has to be said. "Last of the V8s max...sux nitrous" Only it doesnt suck nitrous so will never replace Max's Interceptor
Quick peek at the deathtrap I've been building up for the past few years. Do you think I can run it in Improved Production? I have a CAMS license now.
what...the...HELL..is that that that...monstrosity..?
and more importantly, what lunatic approved your CAMS license?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
