You're thinking along the lines of the previous owner of my car with the battery placement.
Any particular reason for putting the switches on the tunnel and not in the centre console?
I can't take credit, a mate did it on his car, then installed it on mine :D
I'm going to be mounting the fuse box in front of the shifter, which is why I'm putting the switch panel where it is. I have an ERP bellhousing for my RB25 gearbox, and it moves the shifter forward. I didn't want to hit any switches with my clumsy shifting :) I have long arms, so I can still reach it where it is, but I might extend my shifter so I don't hit anything with my elbow.
Mick: nice looking setup there man. I'm trying to get my fuel system done at the moment, but the guy doing my enclosure has just pulled out so trying to get another one done. Never ending delays...
Been doing the rest of the sound deadening today, gave myself a nice cut which i then managed to bash a few times :unsure:
Only the trans tunnel and behind the pedals was left to do so i used a heat gun and scrapper, wasnt too bad a job. Cbf going to get more dry ice :(
I also decided that since i have come this far im going to remove whats left of the dash and take out the heater etc and paint it properly and re wire with minimal wires.
have you go the measurements for that? is it a zeta type 3?
I just picked up a plain black Bride Zeta type 2 Type L from JDM Concept on the forum...
(Care to pm me price you paid)
cheers
Michael
Yeah they were great to deal with.
Anyway did u use the low max rail as well, how much did it lower you roughly. I have issues once i have my helmet on because i have a sunroof, that is 90% of the reason i have thsese seats so im going to be a bit pissed if i still have a problem.
cheers
mine isnt no where near finished yet but here are some photos
it isnt a skyline as u can see
engine is being built (well not right now because i ran out of money) SR20DET bottom end with SR20V cylinder head
this is wat the engine use to look like b4 it under went the SR20V cylinder head conversion
Edited by STR8E180
Whats with the catch can setup in the engine bay?
Can understand why you ran out of money , lots of big dollar parts there :blink:
i got defected for having a breather on the catch can after the defect change the catch can setup so that the breathers are hidden in the airbox while i was there we added another catch can
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
