im sure your wealth of knowledge and performance part collection that you wont have any trouble. :D
Mick, that is awesome. So pumped to see somebody put the effort into such a tidy track GTSt. Then you have Bens cool Targa GTSt... i have to lift my game to make sure my little slug keeps pace with the other GTSts in the build
im sure your wealth of knowledge and performance part collection that you wont have any trouble. :P
Yeh, lol thats the problem. I am good at buyign shit and talking shit. But none of it ever makes its way onto my car or makes the car quicker :)
That said, SO pumped, hoping to be able to post up the old girl with her new paint, kit, turbo setup, exhaust and intercooler, brake setup, suspension, wheels, interior etc. Have had to park it since October 2007 to afford all this crap but pretty excited. I am betting the car will be slower then before... :D LOL usually the case when i fark with something that was not broken :)
I need to come up with a cool sticker for the bootlid that says GTSt Evo II as just about every performance part i have put on the car during the first 7 years of ownership has been replaced the past 12 months so constitutes the second evolution for the car :)
Cheers for the comments guys, and yeah now the fun of putting it back together. I plan to get some double bed blankets from vinnies and lay it over the interior to make it a little less painful when i drop a screwdriver or something :)
Plan to do as many track days as i can this year and then put the 30 in at the end of the year
Will post pics again once the brides, new nardi, pfc and nismo diff go in. Injectors are mostly done, put new plugs on etc just got to wire in the gtr resistor pack.
Roy, how long untill your car is ready, even just some progress pics :) and as far as commitment to the gtst goes im just trying to keep up with you!
Edited by Gts30t
So Ben / Mick...how mcuh weight does it really save and once the carpet is back in how much louder is it?
Roy, as you see I didn't start with a stripped shell so I didn't get the bitumen off the firewall etc, but I measured just under 9kg, about the same as swapping a std bonnet for a GTR bonnet, so worthwhile in my opinion. I don't run carpet, so for me it was mainly to clean it up for aesthetics with the bonus of a little weight. I figure if I'm chasing 2 and 3 kilo savings by using lighter wings etc, then 9kg for a few hours work is well worth it :P
How much noiser? No idea yet, haven't driven it, but since I'm always wearing a helmet, it won't worry me.
Roy, from memory it was about 13kg in total weight removed when i did mine. I dont have the carpet back in mine, with a cheap brand of tyers on the road its not too bad. Its when you hit a rock or in my case have to travel down 3k of dirt road that its loud.
Edited by Boss-zilla
If anyone hasn't come accross my build thread yet for my 32 heres the most recent shots. Just building it to mainly run hill climbs and tarmac sprints. N1 bottom end, gtr-s turbos, tomei head and dry sumped. Can't wait to get it finished.
Troy, might not be a good idea if you want to use the 32 as a daily when you come back. From all reports the removal of the deadening makle the car f'n loud! Especially with semi's on
ear plugs will fix that :)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
