Got some of the R33 stripped on the weekend. just have to take the rear seats out, and the carpets now.
We have the same brakes and air compressors :P
And it looks like my rotors are on the wrong way, thanks for posting that pic up!
the slots don't matter, it's the direction of the vanes that's important. in the pic posted you can just see the curve/angle of the vanes is correct. phunky, yours may have the slots cut the other way in relation to the vanes. (ie with the rotors mounted correctly vane wise your slots may face the other way).
Good to see that everyone has been working hard on thier machines, as have I. I've been working on seting up a set of GTR throttle bodies and plenum on to an RB25. Not a job for the feint hearted. Finaly got a decent tune in to it today. No real power increase but emensly different fuel mapping was need everywhere and took the best part of the day. In the end the power comes on a little earlier in the rev range, has a flatter curve and moved peak power up by nearly 1000rpm in the rev range. Might be easier to power out of corners? will track test and refine tomorrow at morganpark.
Will post up some pics later. Off to do a wheel alignment for gatton street sprints and testing.
Mine are from a GT-R, and are the same brand of rotor, so I think they're on backwards... I knew I'd get it wrong :pirate:
hehe, thats the second time your rotors have been put on the wrong way dane... i did it the first time they went on the gtr, didn't notice until it i'd put everything away and taken the car off the hoist!
This is my baby hopping to have it finished by super lap 2010 but it costs so such.
It has an RB30/26 Motec M800 Alcon's ext and it is all done by Ben at Race Pace Motorsports.
mumma mia! that's a spicy meatball you have there.
any more details? turbo(s)? suspension? it looks very serious, and very nicely done so far. no doubt it will be a weapon as ben certainly knows how to make a quick track GTR. :)
when it's finished I'd be happy to test crash... i mean test drive it for you... :P
Thanks for the thumbs up guys :ermm: .
The Turbo is one of Ben's custom T04Z's on a Race Pace manifold with an HKS 60mm gate.
The suspension will be a set of Bens custom tein's and all links will be Ikeya Formula
I have made an addapter manifold to mount a set of GTR throttle bodies and plenum for my RB25. It has worked quite well but not improved the area of the fine throttle response I was looking for. It has improved and moved the power up higher in revs though.
I'm going back to the old setup.
interesting, i went the rb26 plenum setup on my 25 and i gave alot of response.
Before the setup had full boost (16psi) at 3300rpm
after
Full boost (18psi) at 3000rpm
:sweat:
I'm using the blitz kit
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
