Fark man, that is a great setup but an expensive way to make 250-270rwkws, (not saying its a bad thing) Just grab a 6boost manifold for $800, a 3071 for $1800 and the fraction of a second (tenth?) you will be slower around a track just means you get more track time then others :) Twin gates! Fark me, i understand the gain etc, but a 3071 is pretty punchy to start with.
Actually that setup makes 26psi by 4000rpm and 290rwks at 22 psi at around 7700 rpm :)
Edited by juggernaut1
Actually that setup makes 26psi by 4000rpm and 290rwks at 22 psi at around 7700 rpm :D
Yeh, i recognised the pics from your build up thread and know its a great setup. But to get that good a result it costs money :) LOL, i am a tight ass and live with 19psi by 4300rpm and 260rwkws with 19psi with a pretty doughy power delivery. I have a shits and giggle build all worked out for an RB20 that i think would match it or get similar results, only i need a house with a garage first
Yes you gotta pay to play.
Could be done cheaper tho' ....get Kyle (6Boost) to make up a twin scroll mani and order the 3071 or 3076 turbo and twinscroll housing from Full-Race or ATP in the US or GCG here in Oz and keep stock intake......or if using a highport SR then go the Greddy intake. Tial gates can be had from anywhere. All other supporting mods are pretty much going to be the same regardless of the turbo setup.
As to the worthiness of the twin gates over the single gate version...Geoff Raicer (Full-Race) suggests its worth around 250rpm in which case you may be tempted to upsize to the 3076 over the 3071 for a cooler charge and bit more hp.
The beauty of the twin scroll setup is not so much peak hp (I think single scroll turbos actually produce higher peak hp) but a broader power band and rev range which is perfect for street and circuit duties ......and also the ability to respool the turbo in on/off throttle applications faster than a single scroll setup and because of this ability it actually feels like a big N/A engine which IMO is again perfect for street and circuit duties.
Regarding my setup........26 psi by 4000rpm (although it hauling by 3500rpm) and peak hp at 7700 and power doesn't taper off much at 8,000 (so its carrying torque to the red line) - so it has more or less a 4000rpm rev range which is not bad for a turbo motor.
I've never had much to do with the RB20 but they seem to lack a bit of mid-range torque based on the ones I've come accross at Barbagello.....then again so did my brothers LS2 powered commodore - too slow out of the corners.
But sounds like you've got it all worked out tho' - good luck with it.
PS - my brother ended fitting an APS twin turbo kit to the LS2 to give it some grunt out of the corners. We've never been back out to the circuit since our respective mods but should be interesting when we do.
See, I don't actually think it would work out much cheaper doing it here Ian. My (rough) calculations are as follows:
6 Boost Manifold - $1000 - $1100 or thereabouts (not sure on the twin scroll)
3071/3076 - $2000
Tial gate - $4-500
We're already at around $3500 and don't have a dump pipe or the second wastegate. I actually think the full kit is decent in price in comparison if you could get it for a bit of $4k when the exchange rate improves a touch.
That's what's made me think of it, apart from your build, is the price compared to a full kit here. There's really not much in it and you get the best setup going around
3071/3076 - $2000
Tial gate - $4-500
Hi Dane,
There would also be GST and import duties to factor into the original cost of the kit....unless you bought it in bit by bit....hint hint.
If you like I can pull out my records and let you know the all up actual cost of mine including import duties?
You could then get a quote from Kyle for the manifold and I know he can also supply turbos and gates - so you could get a comparative kit price and do the maths.
Cheers,
Ian
That would be great if you wouldn't mind Ian. I forgot about the pesky GST and import taxes... haven't had to fork out for those for imported goods in a while!
With those tossed in you may be right mate, will be good to get a comparative cost.
Cheers,
Dane
SAU NSW Track Day at Oran Park is now open for entries as well. http://www.skylinesaustralia.com/forums/Sa...-T-t286613.html
This is genuinely one of the last chances so don't miss out....the bulldozers are (literally) waiting at the gates for 1/1/10
Cheers,
Dane
OK Dane - my costs were as follows:
manifold US$1449.00
2 x 44mm gates US$ 698.00
downpipe US$ 349.00
v-band US$ 25.00
3071turb/ex housing US$1271.00
shipping US$ 385.00
total US$4,177.00
AUD at $0.937 AU$4,457.79
Plus
import duty AU$210.82
GST AU$556.78
charges & fees AU$68.20
TOTAL COST AU$5,293.59
Note that there is no import duty on the turbo, manifold is 5% import duty and other parts are 10% import duty
Hope that helps your decision.
manifold US$1449.00
downpipe US$ 349.00
v-band US$ 25.00
shipping US$ 385.00
total US$4,177.00
Plus
GST AU$556.78
Thanks a lot for the Ian, very much appreciated mate.
It seems that perhaps their pricing may have changed slightly, or maybe I'm missing something??
From what I'm entering into the site, it comes up with this:
3076
Manifold
Manifold HPC coating
Downpipe
Tial Wastegate (unsure if this is just for one, which I'm assuming it is as the price doesn't change between twin and single 'gate options)
= $3474 + $238 shipping US
But it's the extra 1k from the Aus government that is the killer...
Might have to confirm with Full Race on pricing if I decide to go that way.
They may have adjusted their pricing given the economic downturn especially in the US.
Actually best to confirm with Aaron Teague at Full-Race as he handles all the sales side of things - email [email protected]
Thanks, shall do.
It also says something about them having a summer sale on the site, so it may be an automatically adjusted price. I'll ask Aaron though, just need the dollar to continue this sweet rise :thumbsup:
Here is the head the head you sold me baron
today was fairly productive, made up some oil restrictors, put the head on etc
sweet ;) It's the most fun I've had giving you head..... :woot:
I wish I could get complete heads as cheap as I sold that one now! Your head was lovingly removed and checked at prime garage so it should be good, in fact Tono at prime was going to buy it when he pulled it down, but I wanted it so we gave him the block/crank/rods/pistons out of that engine as a christmas present instead and kept the head!
it will be a pretty sweet donk when it's done. and I would hazard a guess all up not too pricey either since I know what the head cost ya! hehe.
Here's another update of my 3.1lt big little engine prototype. Ive completed the final assembly of the bottom end over the weekend.
The block is a partially grout filled RB26 05u block, modified RB30 crank(drilled+screwed, balanced, modifed rod journels and slotted for oil squirters), pauter billet rods with 19mm bearings, custom wiseco's with 22mm gudgens and non-interference valve pockets, acl bearings, and dartron sleeves.
Here are a few pics.
Cheers,
Ian
looking good. I think I'm entitled to a drive after it's done. it was my baby after all. going by this thread there is a little beer baron in everyone... :woot:
Sorry Ian, another question... Do you know what section on NS the car you're referring to in this post is located: http://www.skylinesaustralia.com/forums/in...t&p=4594093
I can't seem to locate it.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
