Fark man, that is a great setup but an expensive way to make 250-270rwkws, (not saying its a bad thing) Just grab a 6boost manifold for $800, a 3071 for $1800 and the fraction of a second (tenth?) you will be slower around a track just means you get more track time then others :) Twin gates! Fark me, i understand the gain etc, but a 3071 is pretty punchy to start with.
Actually that setup makes 26psi by 4000rpm and 290rwks at 22 psi at around 7700 rpm :)
Edited by juggernaut1
Actually that setup makes 26psi by 4000rpm and 290rwks at 22 psi at around 7700 rpm :D
Yeh, i recognised the pics from your build up thread and know its a great setup. But to get that good a result it costs money :) LOL, i am a tight ass and live with 19psi by 4300rpm and 260rwkws with 19psi with a pretty doughy power delivery. I have a shits and giggle build all worked out for an RB20 that i think would match it or get similar results, only i need a house with a garage first
Yes you gotta pay to play.
Could be done cheaper tho' ....get Kyle (6Boost) to make up a twin scroll mani and order the 3071 or 3076 turbo and twinscroll housing from Full-Race or ATP in the US or GCG here in Oz and keep stock intake......or if using a highport SR then go the Greddy intake. Tial gates can be had from anywhere. All other supporting mods are pretty much going to be the same regardless of the turbo setup.
As to the worthiness of the twin gates over the single gate version...Geoff Raicer (Full-Race) suggests its worth around 250rpm in which case you may be tempted to upsize to the 3076 over the 3071 for a cooler charge and bit more hp.
The beauty of the twin scroll setup is not so much peak hp (I think single scroll turbos actually produce higher peak hp) but a broader power band and rev range which is perfect for street and circuit duties ......and also the ability to respool the turbo in on/off throttle applications faster than a single scroll setup and because of this ability it actually feels like a big N/A engine which IMO is again perfect for street and circuit duties.
Regarding my setup........26 psi by 4000rpm (although it hauling by 3500rpm) and peak hp at 7700 and power doesn't taper off much at 8,000 (so its carrying torque to the red line) - so it has more or less a 4000rpm rev range which is not bad for a turbo motor.
I've never had much to do with the RB20 but they seem to lack a bit of mid-range torque based on the ones I've come accross at Barbagello.....then again so did my brothers LS2 powered commodore - too slow out of the corners.
But sounds like you've got it all worked out tho' - good luck with it.
PS - my brother ended fitting an APS twin turbo kit to the LS2 to give it some grunt out of the corners. We've never been back out to the circuit since our respective mods but should be interesting when we do.
See, I don't actually think it would work out much cheaper doing it here Ian. My (rough) calculations are as follows:
6 Boost Manifold - $1000 - $1100 or thereabouts (not sure on the twin scroll)
3071/3076 - $2000
Tial gate - $4-500
We're already at around $3500 and don't have a dump pipe or the second wastegate. I actually think the full kit is decent in price in comparison if you could get it for a bit of $4k when the exchange rate improves a touch.
That's what's made me think of it, apart from your build, is the price compared to a full kit here. There's really not much in it and you get the best setup going around
3071/3076 - $2000
Tial gate - $4-500
Hi Dane,
There would also be GST and import duties to factor into the original cost of the kit....unless you bought it in bit by bit....hint hint.
If you like I can pull out my records and let you know the all up actual cost of mine including import duties?
You could then get a quote from Kyle for the manifold and I know he can also supply turbos and gates - so you could get a comparative kit price and do the maths.
Cheers,
Ian
That would be great if you wouldn't mind Ian. I forgot about the pesky GST and import taxes... haven't had to fork out for those for imported goods in a while!
With those tossed in you may be right mate, will be good to get a comparative cost.
Cheers,
Dane
SAU NSW Track Day at Oran Park is now open for entries as well. http://www.skylinesaustralia.com/forums/Sa...-T-t286613.html
This is genuinely one of the last chances so don't miss out....the bulldozers are (literally) waiting at the gates for 1/1/10
Cheers,
Dane
OK Dane - my costs were as follows:
manifold US$1449.00
2 x 44mm gates US$ 698.00
downpipe US$ 349.00
v-band US$ 25.00
3071turb/ex housing US$1271.00
shipping US$ 385.00
total US$4,177.00
AUD at $0.937 AU$4,457.79
Plus
import duty AU$210.82
GST AU$556.78
charges & fees AU$68.20
TOTAL COST AU$5,293.59
Note that there is no import duty on the turbo, manifold is 5% import duty and other parts are 10% import duty
Hope that helps your decision.
manifold US$1449.00
downpipe US$ 349.00
v-band US$ 25.00
shipping US$ 385.00
total US$4,177.00
Plus
GST AU$556.78
Thanks a lot for the Ian, very much appreciated mate.
It seems that perhaps their pricing may have changed slightly, or maybe I'm missing something??
From what I'm entering into the site, it comes up with this:
3076
Manifold
Manifold HPC coating
Downpipe
Tial Wastegate (unsure if this is just for one, which I'm assuming it is as the price doesn't change between twin and single 'gate options)
= $3474 + $238 shipping US
But it's the extra 1k from the Aus government that is the killer...
Might have to confirm with Full Race on pricing if I decide to go that way.
They may have adjusted their pricing given the economic downturn especially in the US.
Actually best to confirm with Aaron Teague at Full-Race as he handles all the sales side of things - email [email protected]
Thanks, shall do.
It also says something about them having a summer sale on the site, so it may be an automatically adjusted price. I'll ask Aaron though, just need the dollar to continue this sweet rise :thumbsup:
Here is the head the head you sold me baron
today was fairly productive, made up some oil restrictors, put the head on etc
sweet ;) It's the most fun I've had giving you head..... :woot:
I wish I could get complete heads as cheap as I sold that one now! Your head was lovingly removed and checked at prime garage so it should be good, in fact Tono at prime was going to buy it when he pulled it down, but I wanted it so we gave him the block/crank/rods/pistons out of that engine as a christmas present instead and kept the head!
it will be a pretty sweet donk when it's done. and I would hazard a guess all up not too pricey either since I know what the head cost ya! hehe.
Here's another update of my 3.1lt big little engine prototype. Ive completed the final assembly of the bottom end over the weekend.
The block is a partially grout filled RB26 05u block, modified RB30 crank(drilled+screwed, balanced, modifed rod journels and slotted for oil squirters), pauter billet rods with 19mm bearings, custom wiseco's with 22mm gudgens and non-interference valve pockets, acl bearings, and dartron sleeves.
Here are a few pics.
Cheers,
Ian
looking good. I think I'm entitled to a drive after it's done. it was my baby after all. going by this thread there is a little beer baron in everyone... :woot:
Sorry Ian, another question... Do you know what section on NS the car you're referring to in this post is located: http://www.skylinesaustralia.com/forums/in...t&p=4594093
I can't seem to locate it.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
