Was thinking that the ride height is nice and low...i know i run mine higher and it looks gay for it. I am not fast so have to remember to look and sound it :D
I have another date with a Caterham, this time an R300 race car. I wonder if the magic has worn off or after driving it i am still going to be hungry for one?
It's not high at all...... it's loaded up in this picture, I'll grab a centre of wheel to gaurd height when I get home if you like fellas?
yeah it looks loaded, i think roy was saying his is high. If u could measure it up when you get time that would be great, clearly whatever you are doing is working :D
How the fark to I multi-quote?
I have played around with rear ride height in an attempt to balance the over/under-steer, and it has a fairly good balance now. Keep in mind that mine is still on standard bars etc, so if you have all that shit upgraded it's likely to be a different kettle of fish.
It'll be flat I reckon, wish I was in your position and booked in to find out mate! :)
Just need to get a POV 1.5 and will see if i can man up. It pains me that i didnt do Eau Rouge flat (though i did it with a lift on turn in)....going to take my skirt off and wear my wife beater this time. Flat or good footage of the OFF!
..AND Ben, i have four Whiteline sway bars you can pick up when you are in Melb. All adjustable, and different diams. Hell try them at PI if you like, or take them home and play with them. I have some new ARC ones so dont think i will be needing them. lol unless the ARC ones are a disaster
Now THAT is what I like to hear........ and if it spins, do not lift, it has to go "in" on the limiter.
TD06-25G in a twin charge setup with a Rotrex supercharger. Should be an interesting setup
Not really, have the 25G there for shits and giggles, if somehow some of the other mods help response (new manifold, inlet etc) But i also have the current TD06-20G, and a TD06L2-20G which i am getting rebuilt with a water cooled ball bearing centre)
Mmmm lot's of Trust goodness there hey? It will be interesting to see if the 6Boost manifold can bring them on boost a bit quicker, especially if you try the 25G out.
I'm fighting urges to get one of these:
It would lack some response, but man it would be fun :)
Yeah, T67 goodness :D
I've been doing a lot of reading on them and have seen a number of graphs on SR20's and they look like they could work really well, and I've always had a thing for Trust turbo's...
With my 272/11.5mm cams and extra capacity I think it'll suit the T67 better than the TD06 (except the 25G), in either 8cm or 10cm form (8cm would be wiser). The hit come 4500rpm would be monstrous me thinks :)
We all know that an rb30 conversion is where it's at! :)
Slap on a 550hp Garrett and you have 320+rwkw with better response than a std/factory rb25 setup ;)
I am tempted to take mine to the next Winton track day, whenever that is, have been giving some serious consideration :D
Below is an older power curve. My car now makes 330.6rwkw with even better response and more torque; as we have since adjusted the cam gears and done a retune
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
