I think they look pretty good. Finally Australia is producing cars that don't simply look like blobs with too much plastic, and yes I did see the plastic around the headlights.
If I were to be given one of these cars or something with the same power from Germany, I would definitely go for the German product however if I was buying it I would most likely be paying 2 to 3 times as much.
Pretty good value for money I say.
Looks good, I like it.. Always liked the now older style F6. The enw tornado would be awesome.. factory 300KW ute with turbo goodness! Someone mentioend power to wieght, that GTP would have a hell of a lot of torque on it. never driven an aussie muscle car but u'd expect if they r selling them overseas, america and the UK, where 'real' muscle cars r really built then they must be pretty decent. Actuall sucks to hear about the commodore GTS-R.. Taken a great name code from the HR31 and made it into a f**kin banana! Would be interesting to see the new one tho and read about it. U know its going to be a good car. maybe the current F6's will come down in price from over 50k second hand.
Liam
Throw some boost into the typhoon. :)
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :P
You sure heard some wild rumours. Also Lightly modded GTST's are already being thrashed off the line by lightly modded XR6T's. Driven a liughtly modded F6 and loved it. Still nothing compared to my GTR :)
Just a quick note on the subheading of this thread...
HSV finally has some competition from the Blue Oval
The turbo six-pots have had it all over the GTS, R8 etc for a very long time, champ.
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :laugh:
man even lightly modded gtst's wont have shit on a stocko F6... until you start changing turbos of course
the xr6t currently run 6psi. the new f6 are going to be running about 11psi. the current f6 run about 9.5psi.
my brother in law has a ba xr6t. his made 248hp (185kw) at the wheels (100% stock). he has put a flash tune in (just an of the shelf one, not tuned specifically for his car.... yet) and pumped it up to 12psi and got 299.3hp (223kw). that is with standard exhaust, standard airbox and filter, and standard intercooler. he going to get a new airbox, intercooler and injectors and get the tune done for his car.
also the sound of the big six hitting the traction control is awesome.
a mate of mine has a xr6t. he has spent a fair bit of money on it (it developed an electrical problem when number 1 piston came out and destroyed the alternator). he had a full forge rebuild, c4 gearbox, and now he needs the diff done. on a light tune on the stock turbo at 18psi he made about 410hp (305kw).
as for the hsv gts-r i didn't think holden had decided if it was actually going to make it yet. and it takes them 7.0L to get 365kw. they have to use big cubes to get the power. atleast ford is getting 320kw out of only a 5.4L
too big, too heavy, and they use too much fuel...
i wouldnt buy one when i know that a japanese turbo car can out handle, out brake, and out accelerate for less money
unless you are talking a gtr or a fairly modded gtst they won't out accelerate a turbo xr. if you honestly think that you need to spend more time at the drag strip.
and as for handling, have you driven one? if not, then what are you basing it off? or have you driven an early e series falcon and are basing it off that? i know round where i live, where the roads are crap and rough, they would out handle a skyline cause they soak up the bumps beter.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
