  • Replies 843
Posted Images
Cant Remember if its been covered and cbf reading through 8 pages.
Pump Fuel or Race fuel? and will it still be gassed up.
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :P
Regards Andrew
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :rofl:
Regards Andrew
In order:
- Race fuel
- Yes
- Didn't sell the box from this car. I still have the C6 in it.
Intake update: I can get a couple more of these (plenum/TB) at $1400 if anyone is keen for one. Just send me a PM and I'll sort it out. They use the std throttle cable and TPS as well.
Adrian
Looking very nice man - how quick are you aiming to go with this???? Going by your nack, I'm not going to be surprised if I hear very near single digit numbers - if not...
Thanks mate. I don't know if this setup will have a 9-sec pass in it to be honest but it'd be nice to do. Not sure if the GT35 has it in it but there's only one way to find out :thumbsup:
Hello Mrs Courier!
These look bloody awesome. The throttle body is a work of art too - can't wait to bolt it up and have some fun!
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :thumbsup: )
Good luck,
Ryan
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :banana: )
Good luck,
Ryan
Thanks for the tip. What did you make it from?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
