  • Replies 843
Posted Images
Cant Remember if its been covered and cbf reading through 8 pages.
Pump Fuel or Race fuel? and will it still be gassed up.
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :P
Regards Andrew
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :rofl:
Regards Andrew
In order:
- Race fuel
- Yes
- Didn't sell the box from this car. I still have the C6 in it.
Intake update: I can get a couple more of these (plenum/TB) at $1400 if anyone is keen for one. Just send me a PM and I'll sort it out. They use the std throttle cable and TPS as well.
Adrian
Looking very nice man - how quick are you aiming to go with this???? Going by your nack, I'm not going to be surprised if I hear very near single digit numbers - if not...
Thanks mate. I don't know if this setup will have a 9-sec pass in it to be honest but it'd be nice to do. Not sure if the GT35 has it in it but there's only one way to find out :thumbsup:
Hello Mrs Courier!
These look bloody awesome. The throttle body is a work of art too - can't wait to bolt it up and have some fun!
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :thumbsup: )
Good luck,
Ryan
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :banana: )
Good luck,
Ryan
Thanks for the tip. What did you make it from?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
