  • Replies 74
Posted Images
Yeah the new WRX looks terrible. But I still say the new STi has potential.
If the STI looked like that pic put me down for one BUT i think it will look more like the
stupid smiling grill thing like the Ring pic posted earlier.
Going by the pics the EVO wins hands down
Looks like i'm keeping the classic forever :thumbsup:
On the earlier STI i have seen either foggies or the covers but then i think it became a STI thing to just have the covers plus its another spot to put some STI stickers.
BTW its Gaz not Alycia ireally should get my own membership :thumbsup:
I saw it in Japan in january. Took these snaps below. It looks pretty cool. A little to 'new-age' and 'edgey' for me. but hey, they have always been a bit of a homo's car....
they even had a mini-me version
hmmmm honestly i doubt that will be the production STi... its waaaay too different from the actual WRX which means thats obviously the WRC car.
much like the WRC version of the ugliest ever, the bugeye, it actually looks half decent.
yeah, I think the pics I took were of the concept version. production version probably is toned down a bit and has an uglier girl standing next to it. or even worse, no girl at all. :P
That pic has being doing the round on the internerd for the last few years. There is no way in hell that Suabru will produce somthing even close to that very bad photochop.
Subaru have recently made a deal with Daewoo and Hyundai. Suabru will be borrowing the ugly stick from those 2 companys and using it on all of there new cars.... Here's just a peak at what Subaru have been making recently...
There's alot of subaru people hoping then new STi will be better looking than the newly released WRX, but really it's hard to make chicken salad out of chicken shit.
Oh and the new WRX.... with a Mazda3 over the top....
I think the X looks great and will be very keen to have a go when they come out.
But have been thinking I'd like to take a look at something a bit different...
3.0L
6-cyl
twin turbo
RWD
and German
The BMW 135i Coupe - http://www.rsportscars.com/eng/cars/bmw_135i.asp
Something about them is pretty cool - I always loved 2002s, and this looks like a grown up version.
BUT... we'll see. Evo X still top of the list for mine, and we'll have the E90 M3 at work soon - so I can always play with that :stupid:
3.0L
6-cyl
twin turbo
RWD
and German
BUT... we'll see. Evo X still top of the list for mine, and we'll have the E90 M3 at work soon - so I can always play with that :P
my old man restored a 2002 tii.. then sold it :stupid:
it was red with a creme leather interior. SO nice....
I was going to wait and buy a X...but local dealer could not comment on whether available in auto. So armed with cash from selling my R34 GTR...i was purchased a V35 which i soon to convert with GTR motor and AWD using V35 gearbox. Looks and performance of latest Nismo Nissan with comfort and performance of auto. Much better then Mitsubishi.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
