  • Replies 175
We have aconfirmed order for 36 units.
The only ones who havent paid that showed interest are:
Fr0st
PX29
Pism
Thrtytwo
MrLag
If you guys still want them, let me know ASAP or unfortunately you will miss out.
Ill send PM's later today/tonight in case you have forgotten etc.
Cheers
Brad
Thanks mate.
The order has been placed so those who have not paid yet unfortunately have missed out.
We have a total of 41 paid for, and ordered. Well done!
Delivery is expected to be to me sometime friday afternoon.
Thank you all for your support on the group buy!!
Cheers
Brad
I have received the order of fire extingushiers!!
I will probably be taking them with me tonight on the cruise, so if you are going and want to get it, come find me. For those that dont know me, i drive an extremely rare Silver R33 GTST S2 2door coupe. [RDIRTY3].
If your not going to the cruise you can pick them up from me at an arranged time. Let me know before you come see me.
Also, if you have paid for delivery, now is the time to PM the address to send to.
I would like to thank Luke and the guys at Revolution Racegear for helping out our club and giving us a great price on these. If you do require any race type stuff (harness, helmets, fire suits, gloves etc) drop in and see them and im sure they will look after you!
Thanks for everyone who supported this!
Cheers
Brad
Thanks for the extinguishers Brad, now to figure out where to mount it! <open to ideas people with 32's :(>
make a bracket upand mount them to the rails of the drivers seat so its easy to access
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
