Taken from s2ki.com forums. (Yes, there are Honda pictures in here)
*disclaimer* I take no responsibility if you mess up!
I wanted a vented hood for three reasons;
1. To let heat (from header, engine, & radiator) escape from engine bay
2. To get cooler air into intake
3. To use the low pressure area above the hood to help extract air from under the front of the car thereby increasing velocity under the splitter and floor of the nose which should increase downforce.
Why not buy a carbon fiber vented hood? The affordable knock-off carbon hoods are heavier and less stiff than the stock aluminum hood. I believe the stock hood weighs 14 pounds. The high quality "authentic" hoods (cwest, mugen etc...) cost a bundle and still need to be painted unless you are going for the carbon look. Some if not all composite hoods require hood pins for high speed use. Oh yeah, and I'm cheap. I planned on venting both sides but ran out of time and decided I like the look of just one side. Still debating.
Here's my solution:
How to build your own:
Please use appropriate safety equipment and don't screw up.
Yes, you are about to cut holes in a perfectly good hood so be prepared.
Remove the hood and the hood liner and support it upside down on some padded saw horses.
Make templates by laying paper over each support hole you plan to cut and trace the edge (use the pencil rubbing technique). Use the templates to cut out some perforated aluminum (clean and paint the both sides of the aluminum). http://www.mcmaster.com/
Use a 3/8" spacer against the hood support edges to draw the hole shape. I left a 3/8" lip for mounting purposes.
Using a UniBit, drill a hole in each corner.
Using an air saw, cut out the shape from the under side - leave a small gap to finish off with sanding.
Use a sanding drum on a die grinder to smooth to shape. I tried using a sandpaper wheel on an angle grinder but it gets too hot and the paints starts to peel back.
Once the shape is close, flip the hood over and apply masking tape on the top side all around the new openings.
Use wet dry sandpaper to smooth the cut and feather the paint. The masking tape is there so if you slip with the sandpaper, you won't scratch up your hood.
Lay 3M double stick tape used for moldings/body work on your 3/8" lip and trim with a razor to fit just inside the cut out (find it at automotive body shops).
Use a fine paint brush and carefully paint the exposed edge with factory touch up paint.
Install perforated aluminum and your done. I used some small sheet metal clips to hold the perforated aluminum in place just in case the double stick tape failed due to engine heat but I ran a full track day without them and everything was fine.
Edited by 403_r32
https://www.sau.com.au/forums/topic/177820-diy-the-hood-hack/
that looks tough as, would look way better with bost sides done but then agian may be too busy, ohh btw if your in melb and ever need any geniune parts for your s2000 pm me, i work in spare parts at a Honda dealer, i dont mind helping out a fellow member, even if oyur not in melb and think your getting ripped pm me ill let you know.
cheers
jarrod
Well, I guess you'd really have to have steady hands if you dont want to respray the bonnet, nevertheless make a mistake! Getting a straight cut is probably the most difficult part. Sanding/feathering down the edges may be a bit tedious, but as long as you take off a fairly even amount and the edge retains an even bevel, the touch up paint would suffice.
The s2k hood was done as I said, just touched up around the edges, and as far as I'm concerned it looks pretty damn good :P As long as you have a straight cut to begin with, and have it all masked off properly there shouldnt be any problems!
Getting more air to run around the iron torpedo of a block will always help lower temperatures. Every little thing helps.
  • 4 weeks later...
  • 4 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
