Full Carbon Fibre Bonnets For R33,180sx,s14a, Civic, Rx8, Evo8
  • Replies 40
thanks for that champ i will edit the post :)
narh not seibon products. that picture was illustration purposes only.
they are being made in china.
if there being made in china i highly doubt they are 100% CF... goodluck with your group buy....
supplier as confirmed they are full cf but i dont think so either..
still these are cheaper then any other else.
racespec sell NON CF bonnets for $700.
pm sent regarding pics of 180sx bonnet.
Edited by whyte
Hate to burst your bubble but DMAX is made in China not Japan.
i never said they were made in japan.
isn't CF illegal or am i wrong?
don't you have S1 bonnet?
sorry no s1 bonnets dude.
you would have to check with your roads & Traffic authories and regulations in regarding to this as every state is different.
lol traders fighting
anyways, is this group buy going or wot?
and can the group buy whyte confirm how much of the bonnet is cf?
yes its going ahead, i've got 2 people interested in the 180sx bonnets. just need 3+ more poeple before i can start making the order and everything will be underway.
my supplier says its full carbon but poeple say its not full cf at that price (which i thikn is true) so its just frp bottom + 2 /3 layers of CF on top.
if you were doing R34GTT bonnets I think you would do some good business .....
yeah i think so too but supplier doesnt have any r34 bonnets unforunately.
  • 1 year later...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
