G'day all having troubles with my 89 GTR
engine has done around 13,000kms since re-build
and the turbo's were highflowed 13,000kms ago aswell
Problem:
I blew a turbo the other day when launching the gtr
what happend:
took off in first changed to second them bang there goes the turbo exhaust wheel, along with smoke pooring out the back, then the car ran like shit then stalled (not sure if thats normal??)... all happend in about 15 seconds,
got towed home, then replaced the turbo with a stock one, after a shit of a time putting it all back together
i decided it was time to start it..
new problem:
car started but ran like shit
oil pressure is good
no smoke from the exhaust
so i left the car overnight.
went to start it today and it just winds over and wont fire it kicks a little bit but thats it.
checked:
checked the CAS and plug
checked the spark plugs
check AFM plugs
Checked fuel side of things just to be sure (except injectors)
checked all plumbing including bov's plumback system
checked everything that i removed to change the turbo over
checked fuses
checked error codes: *55* all good
even checked the battery
when it did start it seemed to run like it did when the turbo first blew....
the exhaust wheel did visually damage the exhaust sensor.. but dont think it would cause any trouble there.
im running out of ideas,
so any help from you guys would be much appreciated.
thanks
SAU.com Member: -GODZLA-
https://www.sau.com.au/forums/topic/178571-gtr-wont-fire-after-turbo-faliure/
  • 3 weeks later...
Ok, so i found the engine was low on compression i wasn't sure what was causing it, so i kept putting oil down the cylinders to bring the compression up and it worked eventually, and the GTR fired up (but was blowing smoke for ages due to the oil of coarse) after leaving it running for quite some time and then driving it the smoke cleared away, so the i thought id try to put some more revs on it got to about 3,500rpm and then i heard a loud whistle and clink clink clink noise then smoke started pooring out the back again... so its blown another turbo..not sure yet if its the one i replaced or the one that was still ok!!
what a shit of a job pulling all that off again!!
if its the rear turbo again i wonder what is causing it to blow lack of oil to bearings? the oil line seemed fine and was pissing out oil when i removed it the first time.
bloody car!!! lol
My first concern is why it blew in the first place. lack of oil? incorrect oil lines fitted for the new highflow job? when u fitted the new turbos, did you use the highflow lines again?
also how was the compressor housing side when it blew? have u dropped the oil to look for metal?.
also you said the o2 sensor copped a hit visually it was damaged. i would change that. and as someone else mentioned. clean out the exhaust and cat. then check ur dump pipes, for cracks or holes, against the housings before the o2 sensor, it could be nothing but worth doing all the same.
sounds like ur having some bad luck., so good luck with it :P
parts of turbo normally get stuck in intercooler but it is possible for them to go further, try compression test first n eliminate things from there...goodluck
how do you suggest that parts of the exhaust wheel of the turbo get stuck in the intercooler?
Also to the thread starter,
I don't understand this..
what exactly did you do?
Do you know for sure that the turbos were highflowed? If yes steel wheels should have been used . It Did you find the broken exhaust wheel? Sounds like the turbo you replaced was a stock ceramic wheel turbo and when it let go some of the ceramic dust got sucked back in the engine the scored the bores, this is why you have low compression .
or maybe the engine was built with low compression?
What compression was the engine built at?
What readings are you getting on the tester?
Also, as someone else said - what were the compressor wheels like?
Presumably to create a better seal and simulate a properly oiled bore? :)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
