  • Replies 178
All i can say is AWSOME day!!! i can deff see who the rebels were of the SAU class :thumbsup::D:D
heheh
cara thanx 4 organising it...that seal was awsome at the bluff...Post up pics later..
x0x
i made this album visible on myspace..cbs uploading some again..lol
http://viewmorepics.myspace.com/index.cfm?...albumId=1264468
dan....i have the pics of the pod for u later..pm me your msn so i can give them to u..lol
Edited by boostd_r32_gurl
lol, that poor r33 gtst.... was pulled over by the cops on the way home for speeding, reaked me out coz the cop came out of a side road just as i was going past, all lights a blazing!!! i dont think he was on the cruise tho. but was a trouble free cruise for me
big ups to cara for organising it, my passanger and i had a blast =P
btw, sif need a myspace account to see pictures!! :thumbsup:
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
