yeah thats what i thought, but i read a thread from the UK aswell as a HPI review and both said you couldnt run it if you have a PFC, which seemed a little weird to me aswell but i thought it wouldnt hurt to check before handing out my hard earned.
well some people in japan also told me they are not compatible. It's possible they are not. remember the Bee-R is basically an interceptor... so yes it does have to work along side the PFC.
only one way to find out though.... but it and tell us what happens.
to be honest they are a bit of a wank. they don't do much except cause some slow damage to your car and make you like like a bit of a tool. unless we are talking for a dedicated drag car, in which case go for it.
b man, the Bee*R rev limiter does not mean fuel cut as vehicle reached certain RPM
the rev limiter is a device used to cut sparks at pre-set condition, so you'll have fuel going through the exhaust valves and igniting in manifold, making flames shoot out of exhaust. there are two conditions that can be chosen, the rev and the launch I think.
That's BS, HPI installed a Bee*R rev limiter in their 4 door 32 with a PFC.
Works with my PFC too.
You can also hook a micro switch up to the clutch pedal on the secondary limiter for a very primitive anti-lag set setup. Works though :thumbsup:
Still in two minds about getting one and installing it...
Purely to use at the 1/4
But smashing it off the limiter (BeeR limiter) and launching it wont make my gearbox happy i dont think.
Im not running a cat also but ive hear there will be jack sheit left in your muffler after using these too? (Sorry to hi-jack)
Using bee*r with a pfc allows you to see the fantastic knock numbers produced.
And it does cut fuel ASWELL as spark.
doupt it cuts fuel, otherwise there won't be flames shooting out at all...I don't get how you'll have high knocks as well? I think the Bee*R randomly cuts spark from one of the 6 cylinders? there's only 3 wires going out of the Bee*R unit if I remember correctly... without spark the fuel won't ignite at all, ignition by compresion alone requires extremely high comp ratio. so no combustion for particular cylinder,
knock is more of sporadic combustion, one main flame and smaller pockets of flame as pistons move up...
+ I dun think it has the function of antilag at launch, looks like it with flame shooting, but because its only 1 cylinder and there's no spark at all, antilag is like retarding the timing so that some fuel exits the exhaust from all the cylinders to put more cha cha in the car.
The main damage is probably to the manifold and exhaust turbine. The main function is to eliminate fuel cut at red line, so the vehicle does not loose power as vehicle stays in red line.
my pfc and bee-r never actually gave me any big knock readings, but when you hit the bee-r limiter the engine check light did come on, im assuming its because the pfc is detecting a error in the ignition which is what the bee-r is designed for.
i had mine installed for good launches on boost, but turns out my car is responsive enough not to need it
when i had mine both connected i had high knock readings and yer a couple months down the track blew the rings on my motor :)
What it does is confuse the CAS sensor, thus not allowing the PFC or Engine comp to know when to fire the coils.
The knock values only show up when there is a big back fire and it's only the shock of the fire ball in your exhaust that is making that knock.
If you tune the gain on the Bee*R down to a reasonably level, it doesn't really sound any different to your normal fuel cut limiter.
I can build about 5 psi at 0 kph with the Bee*R. lift hand brake, depress right foot, stutter stutter, boost up.
It's tops..... but traction is a litle bit of a problem. I'll be hooking up to the clutch before deca.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
