hi all
im wanting to get stage 3 cams (with bigger valve springs of course) in my car but have just found out i also need to get an aftermarket computer,
what i need to know is........can a r34 gtt aftermarket computer be used in a r34 gt (non turbo)????
please help!
thanks
https://www.sau.com.au/forums/topic/180855-help-needed/
safc is like a piggy back comp. illegal tho. you can control the air/fuel ratios.
i would suggest speaking to a workshop and see what they recommend
edit. was just looking on the apexi site. dont know if this would be any good.
http://www.apexi-usa.com/product_electroni...0&pageNum=1
Edited by Luke_ENR34
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3287476
why is it illegal?
i asked my dyno guy whether i can just get it remapped, but he said i need to get an aftermarket computer, it wasnt something i thought i would need.
he said to try and get my mitts on a power fc (he recommends them)
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3287490
you obviously want more power and its going to cost you a fair bit going about it they way you want.
If it were me i'd buy a neo turbo motor and drop that in. Will be chaeper in the long run and even with just an exhaust cooler and a bit of boost you'll be close to 200rwkw's which by the sounds of things will be more than enough power for u!
cheers!
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3288532
well you know! jap import spares always has a neo 6 turbo engine for under 3k i think!
but i don't know much about non turbs! maybe follow the steps of v8's or something! like boring and stroking etc! see what they do and you might get some answers but either than that i'm stumped!
Edited by nos man
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289494
guys i dont want a turbo. full stop end of story.
and when i said i was "happy" with my n/a engine i meant it in the way that im happy to leave it naturally aspirated. and trying to get power out of it isnt gonna hurt
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289511
well i was looking around and i found a few threads on na performance
http://www.skylinesaustralia.com/forums/in...hp?showforum=53
or you can always have a look through some of the threads in na performance! it mentions some cpu's people use like a e manage, gts link, microtech
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289554
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
