hi all
im wanting to get stage 3 cams (with bigger valve springs of course) in my car but have just found out i also need to get an aftermarket computer,
what i need to know is........can a r34 gtt aftermarket computer be used in a r34 gt (non turbo)????
please help!
thanks
https://www.sau.com.au/forums/topic/180855-help-needed/
safc is like a piggy back comp. illegal tho. you can control the air/fuel ratios.
i would suggest speaking to a workshop and see what they recommend
edit. was just looking on the apexi site. dont know if this would be any good.
http://www.apexi-usa.com/product_electroni...0&pageNum=1
Edited by Luke_ENR34
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3287476
why is it illegal?
i asked my dyno guy whether i can just get it remapped, but he said i need to get an aftermarket computer, it wasnt something i thought i would need.
he said to try and get my mitts on a power fc (he recommends them)
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3287490
you obviously want more power and its going to cost you a fair bit going about it they way you want.
If it were me i'd buy a neo turbo motor and drop that in. Will be chaeper in the long run and even with just an exhaust cooler and a bit of boost you'll be close to 200rwkw's which by the sounds of things will be more than enough power for u!
cheers!
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3288532
well you know! jap import spares always has a neo 6 turbo engine for under 3k i think!
but i don't know much about non turbs! maybe follow the steps of v8's or something! like boring and stroking etc! see what they do and you might get some answers but either than that i'm stumped!
Edited by nos man
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289494
guys i dont want a turbo. full stop end of story.
and when i said i was "happy" with my n/a engine i meant it in the way that im happy to leave it naturally aspirated. and trying to get power out of it isnt gonna hurt
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289511
well i was looking around and i found a few threads on na performance
http://www.skylinesaustralia.com/forums/in...hp?showforum=53
or you can always have a look through some of the threads in na performance! it mentions some cpu's people use like a e manage, gts link, microtech
https://www.sau.com.au/forums/topic/180855-help-needed/#findComment-3289554
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
