Hey guys,
Just bought some SSR Professor SP1 rims + tyres and I want to respray the center piece (spokes) a gloss black instead of the silver it is currently.
I can see it just has bolts laced around the outside of the rim that bolt it in. I would need a special star shaped alan key to remove them but what im wondering is ..... is it as simple as unbolting and bolting back in once painted?
Do I have to consider anything such as torque or tightening order? If so, help? :D
Ta.
Ryan
https://www.sau.com.au/forums/topic/181052-3-piece-wheel-dis-assembly/
well yes, yes you do. Just like anything you will need to tighten them in a star sort of pattern.. N,S E,W, NE, SW, NW, SE etc till they are all done up and you will need to set them to the right torque. Also if you take the bolts out you would probably need to replace them as alot of high strengh things like that need replacing once removed as it caused a very larger stress on them. Call the manufacturer and ask for their price.... or... sticky tape mate.
Find a good wheel repair place. They will be able to do it for you. Or at least give you some advice.
Disassembly you can probably do your self, but reassembly will require resealing and balancing of the rim. If you separate them yourself then you should also index all the pieces so they go back in the same orientation.
my advice is if you can do what you want to do without seperating (ie masking off areas) then do that. I've seen so many people that have split up 3 piece rims only to have a bastard of a time as once re-assembled they did not seal properly anymore and took a lot of farking around to make them good again.
i took my old jap 16" apart to respray the centres black again. wasnt too dificult getting them apart, torture putting them back together again. id say get them pro done or mask em off especially when theyre Professors. dont want to bugger up those babies!!
hello!! i used to work at a tyre and wheel joint in melbourne and it really isnt that hard we used to do it all the time.it really is as simple as pulling them appart stripping off the old paint with paint stripper then undercoating and painting.putting them back together is quite easy but they should be torqued tho n thats easy to do with a torque rench and you can pick those up for around 60bucks then add in the paint and the stripper and it shouldnt cost more than 120.just remember you have all the time in the world so take your time n itll be fine not to metion much more rewarding.good luck...peace
