Hopw the hell do you do it?
I don't care if youc all me a noob etc, but i don't know.
I'm not talking about leaving 11's on the ashphalt.
I'm talking about how you keep the rear wheels spinning whilst stationary.
Thanks.
https://www.sau.com.au/forums/topic/181218-how-do-you-do-a-burnout/
OK, so basically...
On the strip, depending on whether your car is auto or manual...
Auto - One foor firm on the break and then other on the accelerator (try not to rev car above 4000rpm)
Manual - Dump Clutch to get wheels spinning, then begin to apply the break
On the street - Drive like a normal road user!!! save tyre shreading for the track....
none of this hoon behaviour shit as it gives Skylines a bad name!
Another way you can do it is hold the brake on with ur right foot then use your heel of your right foot to work the accelerator. Have the car in like first gear and hold some revs with your right heel then let the clutch out reasonably quick.
Use more or less brake with your right foot so that you hold the car still but not so much brake that you stall the motor.
Yeah but as above you are best keeping that to the track.
Na you dont use handbrake. Your skyline is RWD unless a GTR so you only want the front brake on to hold the car still. There is a thing you can buy called a line locker which connects up with the brake lines to stop pressure getting to the rear brakes so when u put you foot on the brake only the front brakes will work.
This is however not legal on street cars.
Ideally you want no braking on the back wheels so that you can do stoppies easyier.
the easiest way is the heel/toe trick.
just keep it at about 5000rpm. if you are running streety tyres there is no need to do a big smoke burnout. just enough to get the water off is all. if you are running slicks then you need to get heat into them so a bigger burnout is better. that is where changing into second helps. you get the tyres spinning faster which creates more heat.
the handbrake only works the rear wheels so there is no point using it for the burnout. you can use it to load the motor up on the start line though if you are in a manual.
i wouldn't try starting in second unless you have a good clutch or crap tyres.
well thats what i did for several minutes on a skid pan and looked back over the vidoe and it sounded like a noob who was just burrying the pedal...
at the drags u dont want to be bouncing off the limiter......its got noob written all over it......i know cause i used to do it....
OK, so basically...
Thanks mate.
And i don't do it on the street.
To be honest, i need to learn how to drive the car before i even start trying to act like i know how to drive.
The reference up there was just so you guys know what i meant :laughing-smiley-014:
Now i can afford it, i'll stick to the tracks and skidpans to be a HOON :)
dump 2nd gear, hit the brakes sit on 7,000rpm and shoot flames :).. thats if i do one that is :P
or if u wana look cool dump 1st play with it a bit, hit 2nd and limo for around 50m :D
www.youtube.com/lthlrb
Edited by LTHLRB
If you are in the wetbox its quite easy. No need to dump the clutch then reach for the brake pedal. Just heel and toe your loud and brake pedal, Lightly on the brake is all you need, second gear, a enough revs to be around boost and slip the clutch. If your diff works well you wont go left or right so concentrate primarily on your tacho. Just float the revs below the limiter till you feel the tyres start to bite. You are now good to go.
Dont snap your foot off the throttle, ease it off whilst taking your foot from the brake. Easier on the car that way.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
