Frozenwaffles:
The insert for the coolant hose was loose on mine aswell. It took it to the exhaust shop and got them to spread it with a machine they have ever so slightly. Then put a heap of sealant on and it tapped in fairly easy with a rubber mallet. The nipple were pretty hard to get into my housing, but they did go in. Just make sure you use some thread tape. The bolts in my throttle body and a bit off. The bolts they supply don't fit so I dodgied up mine with some other bolts I had. Need to go over mine again and fix up the rough bits I rushed. Im working in a different state and was due to go back, so she was all rushed because I needed to shift the 33.
I forgot to add...
It wasn't a perfect casting. Only one major defect which was underneath where the cooling pipe bolts on. It has 6 bolts I think. They all went in except one because the cast hole was about 3mm out. I just used extra sealant and bolted the rest up. It hasn't leaked and runs sweet.
What were the ebay jobs going for?
Edited by M3ld
  • 4 months later...
In regards to the coolant bleed point....
Because the front facing plenum sits lower then where the radiator hose comes out of the plenum and re-joins the radiator... do you need to put the bleed point back in as the highest point would now be the radiator top tank and should bleed itself when running and filling with coolant
Correct me if I'm wrong but thats what I thought
i love it when people get caught taking credit for other peoples work: http://rb30det.info/?m=200902
i'd go at him with a bat mate lol.
how are the people who dont have a bleeder in their cars bleeding the system? im having issues getting it bled with a thermostat in.
isnt the top radiator tank the highest point in the cooling system now as opposed to the throttle body being the highest on the stock setup?
Correct me if im wrong but with the front facing plenum the radiator fill point should be the highest point and will bleed from there once the thermostat is open?
well because the thermostat's job is to trap coolant, air will find a way of getting trapped in there too which is why there is a coolant line coming from just behind the thermostat housing which leads directly to the bleeder.
But isnt that only till the thermostat opens and lets coolant pass through? So when coolant reaches temp and opens thermostat it will be possible to bleed the system
I relise this isnt the best way to do it but will work yeah? Have the plenum on just finishing a few things so just need to know if this way will work
im sure it will work but not very quickly...
now with no bleed valve my steps are:
[car off]
- fill up the radiator all the way with a sealed bottle on the end of the filler, fill the bottle half way and pump the top hose till the bubbles stop coming up (keep filling up the bottle so it has at least half of it full. then do the same with the bottom hose.
- turn the car on
- rev the car up and down to around 3000rpm every 30 sec or so till you get to operating temp.
- when you get to around 90-95 degrees switch the car off (95 deg is pretty much half way up the temp gauge, your car will normally sit around 2mm under the half way mark).
- leave the car off for around 30-40min till the temps go right down then repeat the steps again till you dont need to top it up anymore.
i usually go for a drive after ive filled it up the first time though.
hmmm my cars never hit 95 i dont think, Got PFC and the normal i usually get is 82 or so. Thermostat opens at 76 i think anyway so anything above that will be fine. Will try what u suggest, sounds like a good way to go about it
Cheers
  • 1 month later...
On an entirely different note , does anyone know the size of that big mother of a brass nipple on the bottom ??? i've got a powdercoated one and my threads are in imperial 0_o ...
I am part way pulling it all to bits.
How does one get the bolts out that hold to two parts together under the plenum nearest the block?
Can one person do it or do you need two?
Any help would be much appreciated. Please PM.
Edited by 66yostagea
by 'two parts together' do you mean the plenum and runners?
you need to get under the car and use a ratchet with a LONG 3/8" extension (because a 1/2" is too big/thick), what i did was feed 3 long extensions up one at a time because it was a little tight under the car.
p.s. be careful of the china copies guys, a mate of mine got one of these and i quickly noticed that the furthest front water galley in the plenum was non existent. we has to re-drill and de-burr it out. he was about to install it without checking so definitely get your gasket and make sure everything is where it should be.
OK its all out and partway back in. Thanks for the advice.
Have a bit I dont understand........"Use our bit of fuel line, and some ingenuity, and extend the water line to the nipple below" Where is this nipple hiding??
Also to the rear of the pipe being extended, there is a small pipe bent in a U shape. Is this some sort of bleeder or vent pipe?
read the instructions and look at the pics carefully mate. the 'nipple' is from the fuel rail that you had to trim. you clamp the 'nipple' (sawn off piece of fuel rail that you cut up earlier) and clamp it to the water hose.
what kind of material is the pipe? if you're talking about the one going around the back of the head, its the water feed to the turbo. otherwise, take some pics and we'll be able to identify it for you.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
