Im planning on doing the same sort of thing. A friend of mine has experiance tuning Rally cars running Motec computers.
We want to buy this to try out on my car and then will probably do some weekend tuning for people.
Not aiming to make serious cash or a business out of it just for the love of cars and to learn new things.
I want to order it now so i have it by the weekend but no one has answered my emails
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3304976
It is realtime tuning the factory ECU. and as we all know the factory ecu is better than going aftermarket no to mention you already have a base tune to work on.
I have seen many pics of the software and it looks pretty impressive
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3305009
I've got a chip on my car.
Hyperdrive in Perth tuned it up.
Worked awesome !! Soooo much better then pulling chips in and out.
http://butters.throwinghandles.com/file_st...ts4livedit1.jpg
Car is R32 gts4 on stock turbo / boost hence the low power.
But has Z32 afm, gtr injectors/cooler and cat back.
If you want one, worth a call to http://www.hyperdrivems.com.au/ I think there getting them in.
Edited by Butters
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3305026
One of my mates has it. It's a nice piece of kit. The interface is fantastic.
It was used to tune his SR cefiro.
Have you tried getting it through plms? http://www.plmsdevelopments.com/realtime.shtml contact details are at the bottom of the page.
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3305379
The nistune you remove your chip and insert the board. The only other thing you need is a consult cable.
No Emulators !!!
Then you can real time tune through the consult port.
The software is kinda simular to the power fc data-logit. Same sort of logic.
Its very good. Has lots of features and more on the way.
Edited by Butters
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3305381
I got 2 friends who are hassling me to get the software and get this on the road. But i would need 3 other people to go into a group buy before i will do it. PM me if interested.
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/181930-nistune/#findComment-3305589
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
