just read the entire thread, and this sounds like exactly what im after.
so can these chips be installed into an r34gtt ecu? do you nistune guys know of any tuners in tasmania who can tune your stuff?
how much for a chip fited to my ecu? ready to be tuned, or any other options?
cheers
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5071256
Prices and details are on the website, I'm getting the website updated soon to quote people on everything...
R34 GTT - Type 4 board $260, installation $60, postage $15 + GST = $335
Call around Tassie and see who is willing to tune it since we dont have anyone listed there yet. I know a few people there have gotten tuned using their licence but no one has signed up as a workshop. Most workshops have signed up after using the system as we dont advertise in managzines etc its been mainly word of mouth... internet helps too!
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5071381
cheers
Contact SPG- Nick Summers pushes out some great tunes.
Also Mobile Mechanics- Martin is handling my install.
Both in Hobart/Moonah.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5074431
  • 3 weeks later...
hi mates,
i've got ecr 33 rb25det with auto transmisson
could you pls advise what ECU+nistune is suitable for my car?
i know z32 and r32 ECUs are ok but what kind (turbo, non turbo, Auto transmission or manual)?
also - how will i tune my car if i will install nistune? for example when i add some modifucations, as FMIC, what should i do with Nistune?
Edited by 427
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5108936
  • 1 month later...
hi mates,
also - how will i tune my car if i will install nistune? for example when i add some modifications, as FMIC, what should i do with Nistune?
I prefer to use the later Z32 ecu's but main concern is to get a turbo auto ecu as a manual one will give you shift inconsistency's.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5153952
Can a nistune tunner explain to me how the latency settings work? It shows the values in (us) ever time I look at it my head starts to spin.
nistune uses "us" or micro-seconds to measure injector latencies. as most injector latencies are given as milli-seconds you need to convert it. ms * 1000 = us
so an injector with a 0.7 ms latency, is inputted into nistune as 700 us. an injector with a 1.3 ms latency is inputted as 1300 us.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5154242
is there nistune software for a MAC computer?
software designed for mac, no. but, you can run nistune through a Windows VM with a program like Parallels, it runs fine this way. thats how i've been running nistune at the moment, until i get an old windows laptop i have up and running.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5154283
Has anyone tryed running blow through with the ford lightning maf meter?? And can nistune support injectors as big as 800cc's or so?
I have used blow through on a few cars (requires alot of work in the AFM voltage table) and 1000cc injectors on E85 without issues.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5154794
Wow thanks that clears it up a lot for me.
https://www.sau.com.au/forums/topic/181930-nistune/page/10/#findComment-5155793
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
