Ok well thats good and bad news :( Good news its actually chipped bas news its not nistune :(
So how am I able to tune this ecu? I was going to buy a consult cable but now it looks like my ecu is not easily tuneable
Does anyone know who chipped my ecu? like what brand or whatever? cheers for all your help
No it doesn't have a nistune. I has been chipped though... Its got a socket with UV eraseable EPROM
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5615513
the same way any other chip is done, find someone with a chip eraser etc, its crap though takes ages to get any real changes, just fork out for a nistune, about $300 installed usually and maybe 2-800 for a tune depending how many mods, if its basically stock they prob have a good base map and only need 30mins touching it up.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5615943
Question.
Will a map burnt to the Nistuned ecu be wiped if you disconnect the battery terminals (i.e. the method for resetting the factory ecu)?
No, just like the factory one it will simply revert to the programmed maps, deleting any self adjustment the ECU had made to fuel and ignition maps.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5621785
Question.
The factory ecu doesn't really learn much, it has a knock map and a normal map, all you really reset is the ecu flags which if accurate will be restored on reset anyway.
So no it doesn't reset anything more than it currently does.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5621909
I received my nistune stuff last week :)
When you order it they ask for ur ecu number on the casing, Now is this to put a stock standard base tune on the chip?
So if I install it, would the car drive/idle like the stock ecu ? Is this fine for the car?
Or is driving around with the nistune chip in the car before it gets tuned a big no no?
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638520
They ask for ecu number incase you have an ECU they haven't seen before or can't use (R33 GTR ECU for example), the stock map is pre-loaded (100% the same as the factory map) and will be exactly like driving with an unmodified stock ECU.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638545
Be like you hadn't done anything to it, they will load a stock map on for you, if it was the wrong map or untuned there is a high likely hood it wouldn't even idle so you couldn't do much damage.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638548
  • 3 weeks later...
Matt, I think one our WA guys has been given a bum steer.. I know you do board for auto series 2 Stageas and I was fairly certain you do board for manual series 2 Stageas (RS4S) however he received this reply..
Hi Mike,
Thanks for contacting ***.
The Nissan Stagea RS4S Series 2 with manual transmission has an ECU which is currently not supported by NIStune Software.
Feel free to contact *** should you have any further questions.
Pretty sure he has a 0V801 ECU, can you please confirm? Would have sent you an email but I'm at work :P
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5665967
The guy has been misled. MT SII RS4S is supported by Nistune for more than 3 years now.
I'm using exactly 0V801 ECU with nistune and have a mate here who's using Type 4 board programmed with 0V801 image in his AT ECU. Neo ECUs are actually interchangable - I was running RWD R34 ECU (AA500) with my Stagea motor for two months with no problems at all.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5667436
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
