I have negotiated some good prices on a few R33 GTR's to look at on the weekend. Some are Vspec and some are not, so what are the differences and should they affect the purchase price significantly?
The reason i ask is one particular car is presented beautifully and is a non V spec vs another which is also well presented but not finished off as nicely but is a V spec. Both have been negotiated down to within $500 of each other with the V spec being the cheaper one. :P
Edit: managed to type the right thing into search to get a result. From this i get the physical differences but do you guys percieve the price differences as an issue or not? It seems that most GTR's have aftermarket suspension anyway and the active diff is supposedly nothing special.
EDIT: See post 12 for update and add opinions please
Edited by fieds83
https://www.sau.com.au/forums/topic/182060-v-spec-vs-non-v-spec/
And check REVS and the written off register in the state the cars are registered.
There are a few (well quite a lot actually) cars out there that aren't what they are being sold as.
Old saying "if it looks to good to be true it probably is"
Go on the condition of the car, v spec doesn't really carry much of a premium.
Edited by WRRR
From what ive heard the V-spec is better, dont know y tho, i think it may have had better breaks but im not too sure
Don't be offended but if you don't know what you're talking about what's the point of posting... too much time on your hands?
This guy has the right idea.
I absolutely agree that i should buy the vehicle that is in the best condition and i would not do it any other way. So basically the conclusion that we have come to is that being V Spec does not carry any weight to the pricing of a GTR due to it becoming irrellevent once the vehicle is modified anyway.
Thanks for the replies.
Edited by fieds83
I would be concerned that the grey car has sedan headlights (silver instead of black surrounds) this is a tell tale sign of front end damage at some time in the past.
Also cars with 320km speedo's have questionable km's because these are not the original speedo's.
I have a R33 GTR V-Spec and I can vouch for the additional grip that the active rear diff makes in wet conditions. If you find two cars in the same condition then go for the V-Spec but if the non V-Spec is in better condition then it would be a better buy.
There are also a lot of V-Spec's that are just a sticker so make sure that you run the VIN through FAST to make sure it is genuine.
There is a FAST topic on these forums where if you provide the VIN and Engine number then they can check the FAST software and confirm if the car is genuine for you.
Some rebirthed cars have been identified this way where the car leaves the factory white but pops up later black with the engine that also came in a black car. It is funny how these cars also have the vin plate attached with non factory clips.
This is for 33 GTR's only.. 32 and 34 i don't know as much about differences.... but you could have searched....
Vspec has active LSD which is a bit of a wank, more to go wrong with a pump and stuff with it, plus if you want to change it later to a tighter diff you have to get a non-vspec diff to do the change over....
Vpsec has the faster attesa computer 1/1000th of a second rather than 1/100th... not sure how much difference it would make... i'd guess not a huge amount....
Vspec has stiffer suspension stock.... but most people change suspension anyway...
Brakes, front bar, front lip etc... are all identical between vspec and non-vspec.
As people have said a lot of non vspec have the sticker.. check the rear diff for fins to see if its real.
Personally i'd pick the better condition car...
If you refer to my first post and the time of the edit you will see that i searched within minutes of posting this up. I had been searching beforehand i just had not managed to type the right thing to get a result.
Thankyou for your input regarding the differences, any extra information is helpful.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
