  • Replies 83
exhaust cam gear + S-afc, thermal wrap the dump pipe + BCPR7ES-11 plugs with 0.9mm gap. Add a good clutch and a light flywheel for something that will get you close to a 12second 1/4mile on the factory turbo at about 10-12psi,will get your present 230hp on that dyno at less than 4500rpm (think BIG torque gains).
Killer T is the 2nd best Forum member skyline of any model(after Gavs R) on this dyno so far but his car is in its street set up Gavs was turned up for the Shootout. But the thing here at the moment could change that by another 200rwhp soon but I will keep quiet on that and the owner can shock you all at a Shootout in the future. Rob77 has a big weapon in hand(sounds bad)to garranty his 300+ club membership.450rwhp is the best GTS ever on my Dyno so far and 620 for a GTR ,740.4 is the best car ever
but was 8.2L drag car with lots of NOS.We are doing Blowen
big block on Alky soon that should make 1500-1700rwhp in a Vintage Willys Rod.
  • 1 year later...
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
