  • Replies 51
A& B MOTORSPORTS
DYNO DAY
WHEN: 6TH OCTOBER
TIME: 4PM TILL LATE
COST: $35 PRE ENTRY (29TH September) $50 ENTRY AFTER THE 30TH
1ST: $600 VOUCHER FOR ANY OF A&B MOTORSPORTS PRODUCTS
2ND: $300 VOUCHER FOR ANY OF A&B MOTORSPORTS PRODUCTS
3RD: $150 VOUCHER FOR ANY OF A&B MOTORSPORTS PRODUCTS
RULES
THERE ARE NO RULES MOST HP WINS UNLIMITED BOOST AND
UNLIMITED NITRIOUS
REQUIREMENTS
CARS MUST BE WARMED UP AND READY TO GO .CARS MUST ALSO
HAVE GOOD TREAD ON THE TYRES
CONTACTS
PAUL: 0410 460 346
WORKSHOP: 99059523
Edited by craked
name down now, pay on the day? $35?
or do u need pre-payment for that?
pre payment needs to be paid for before the 30th september to do so please call paul 0410 460 346 or workshop on 99059523 and ask for paul
what are A&B motorsports products?? please list
please go to aandbmotorsports.com for the list
i see you guys sell booster kits: http://aandbmotorsports.com/boostkit.html
do you guys actually believe they work?
we put a few on the dyno with before and after reading they make adout 5-10hp more
im so in. but what time is late cos i have baseball on that arvo. plus i know atleast 15 cars that will run aswell
all depends on the turn out but hope fully into the early hours of sunday morning
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
